oil filter wrench
Started by dan miller, May 03, 2011, 11:40:28 AM
dan miller
Can anyone supply the part number for an oil filter wrench - preferably NAPA - that fits a M900?  I'd like to find one that fits the facets of the filter.
Thanks, Danny
Ddan
I've got one and it doesn't grip the filter well enough.  I don't remember the size but I don't recommend that type.
Ducati Monster Forum at
www.ducatimonsterforum.org
671M900
I use one of these, got it at my Kmart:
671ducati.wordpress.com Record of Progress!
CETME
I use this:  Craftsman strapwrench. Works like a charm, only $15, made out of aluminum. Tough as hell, and does a million other jobs:
2001 Monster S4
2004 Aprilia Tuono
1992 Honda Nighthawk 750
i use my teeth.
or if i havent brushed my teeth yet, i use the autozone one for $4.99 or thats how much i bought it last time. dont forget that you dont need a filter wrench to PUT IT ON. otherwise u will be using the screw driver technique to remove it.
northerncalguy
MotoMFG has a great CNC wrench for Ducati filters.
dan miller
Thanks everyone.  Too tight/waterpump pliers or screwdriver for removal is OK.  Too loose/oil squirting on the rear tire is bad.
I can't get much of a grip on it to tighten, and hand tightening it with a oil filter socket would make me more comfortable.
Thanks again, Danny
Will try Autozone
671M900
Also, the KN filters have a hex welded on top of it.
Quote from: 671M900 on May 03, 2011, 06:18:10 PM
This.
Chris Kelley at CA Cycleworks sells them.
With either that, or one of the claw types that fits on a ratchet, you can use a torque wrench to get it exactly where you want it. You can do that with a cup style, too, but most of them that I've used were too thin/flimsy to give much grunt.
however hiflo filtro filters are half the price...if you dont go ballastic on the oil filter then it shoudlnt be so tight that you need a hex socket to remove it.
True, but in my experience "hand-tight" = slow leak.
Single-purpose tools suck.
how many people actually have a channel lock at home unless they do their own plumping???? those things arent cheap either.
booger
#14
Quote from: Buckethead on May 03, 2011, 06:58:44 PM
I have never had a screw-on oil filter leak when I have tightened it by hand. Never.
next time man up and put some effort into it [cheeky]
I've used a wide rubber band to get a grip on the filter for hand tightening, and even loosening. But I've got the grip of a bear.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
