Slightly uneven brake pads; ok to still use?
Started by daftduc, May 04, 2011, 08:25:27 PM
daftduc
So I got some new rotors for my bike.  While I was waiting for the rotors to be delivered I inspected the pads.  They have plenty of life left in them but I noticed one pad was slightly unevenly worn.  One side of the pad has about 1mm more material than the other side.  This was likely due to a caliper issue which I have since taken care of.  I'm just wondering if the pad is ok to still use.
Don't look at this.
Ddan
You could probably use the old pads, but I would use fresh pads on new rotors.  If you do use the old ones, put them on a belt sander to remove any glaze and expose fresh friction material, and regardless of using new or old pads  make sure you bed them in properly.
Ducati Monster Forum at
www.ducatimonsterforum.org
Yup. What ^^^ he said.
New pads are cheap. Think of this as an excuse to try a new compound with a little more/less bite than stock to see if you like em.
