January 09, 2025, 12:51:21 PM *
Author Topic: diy luggage rack  (Read 7417 times)
live2ride
monster 750 dark
« on: May 05, 2011, 08:15:27 PM »
here's my take on a diy luggage rack.  i asked on another thread about carrying luggage with a passenger.  with no affordable options, i took a trip to home depot and $30 later, had a rack that held up to some extreme storms and 1200 miles.
so to start, the simplest design is 2x 30" pipes, 2 elbows and a 8" pipe.  the problem with this is that it blocks the brake light. you can relocate the brake light, not care, or build around this.  i built around it by moving the luggage part upwards.  thus the more complicated design.
its basicallly some black 1/2 inch pipe, t-ends, elbows, and 2x 8"nipples as crossbars to create this.  the only problem with the design if that all the pipes are right hand threads (righty tighty, lefty loosey), this prevents you from building a box.  don't see why?  go to HD, pick up 4 pipes, and 4 elbows.  try to make a box and you'll see the issue. you can resolve this by threading one pipe fully, then start unscrewing it as its screwing in on the other end.  (i realize this sounds a bit complicated but you'll see what i mean if you have it in front of you).  I thought this idea was very sketchy.  i didn't want my rack falling apart on my trip.  so my way around this issue was to make a crossbar differently.  above the lower t-pipe is a 3.5 inch extension nipple.  what i did was buy a 3/4 t-pipe with 1/2 reducer.  this is a T-pipe where the two of the ends are 3/4 inch and the 3rd leg of the T is only 1/2 inch.   i connected 2 of these with a half inch diameter 8" nipple.  then this slid over the 3.5 inch extension on the rack.  this creates the top crossbar.  of course if your store stocks left hand pipes as well, this can all be ignored.
sorry if the explanation is pretty crap.  i've been meaning to write this up for a week and been ignoring it.  i figure a half ass job is better than none for those who wanted to see it.
i wrapped them with some foam just in case my wife's back was resting against it and to prevent the cords from sliding much.  the foam is sold in the same section. it was like a dollar for 6 feet or something.
the black cast iron elbows were all rusted as it rained heavily during the trip.
i'm sure you can design something better but hopefully this will help you with a starting point.
shopping list was as follows (from memory)
2x 18" black half inch pipe
2x 12" black half inch pipe
2x 8" black half inch pipe
2x 3" black half inch pipe
2x 3.5" black half inch pipe (why a 3.5" and a 3"? because 3.5" was on sale.  seriously.  you could use 4x 3" pipes.)
4x half inch elbows
2x half inch caps
2x half inch T-fitting
2x 3/4 inch to 1/2 inch reducing T-fitting
the long pipes were inserted between the grab handles and the seat.  it worked fine for a 2000 750 but ymmv.  tied down with paracord and safety wire for good measure.
sorry there isn't better pictures of the setup.
« Reply #1 on: May 05, 2011, 08:48:01 PM »
WHAT! why is the bike outside the tent? selfish!
Mojo S2R
. Dark Mojo .
« Reply #2 on: May 05, 2011, 09:10:30 PM »
Nice DIY project.  Thanks.
« Reply #3 on: May 06, 2011, 12:03:27 AM »
http://www.matthewbarr.co.uk/sounds/crude_effective.wav
live2ride
monster 750 dark
« Reply #4 on: May 06, 2011, 08:22:00 AM »
i think its obvious i'm more engineer and less artist.
if it works, it works.  it can't work more than 100%.  it can only be prettier
at $20 a day camping, 55mpg on avg for the trip, cooking at the campsite, and a $30 diy luggage rack, this trip ended up being well below my budget.  great way to spend a week.
but i do think the ferries and toll came out to over $80.
a crappy economy isn't a reason not to enjoy what's out there, enjoy the bike, and enjoy a nice getaway with the wife.
campsites (on the beach) -
croatan national forest - NC
cape hatteras national seashore - NC
first landing state park - VA
edit - oh yea, that windscreen?  not meant for the bike.  simply zip tied for the trip.
« Last Edit: May 06, 2011, 08:24:12 AM by live2ride » Logged
« Reply #5 on: May 06, 2011, 10:43:51 AM »
Sand blast it, remove the elbows, weld it together, blast it again, and powdercoat. Wink
live2ride
monster 750 dark
« Reply #6 on: May 06, 2011, 11:31:06 AM »
eh.
it came right off as soon as i came back from my trip.  plus when its on, its probably loaded up so you can't see it.
but if you are offering to blast, weld, blast and powdercoat it, then i wont stop you  Grin
pitbull
« Reply #7 on: May 07, 2011, 04:48:51 AM »
I think it's perfect.
If I hadn't found a cheap ducati performance top box rack and box, on ebay a few years back, I was planning to make a similar DIY setup with aluminum strapping.
choprdav
« Reply #8 on: May 09, 2011, 12:21:06 PM »
Here's what I did...
Took some 1/2" conduit and bent it like I wanted it, added a little rack to the back, added some pieces so I can clip it onto the grab handles, painted it black, and wrapped the top part with pipe insulation and black duck tape.  I had my doubts about it strength, but for $10 worth of stuff I figured it was worth a try....and to my surprise, I can strap a small tent and air mattress to it and it holds really well even with my GF leaning against it.
Sorry about the shitty pics...but I hope you get the idea
dropstharockalot
Sex-Toy Bludgeonin'
The Teabaggin' Dragon
« Reply #9 on: May 09, 2011, 01:19:46 PM »
No worries/issues with the pipes between the grab handles and seat jostling loose on bumps?
Also, you do you keep the saddlebags from scraping the tire/hugger?
Thx!
'96 M900
live2ride
monster 750 dark
« Reply #10 on: May 10, 2011, 09:16:04 AM »
no, the pipes were held in place with rope and safety wire.  it wasn't going anywhere
the saddlebags don't rub if there isn't much weight on the bike.  however, with it loaded and my wife on the back, this became an issue i wasn't planning for.  have yet to figure out a good way to remedy this issue.  there are ways, just nothing i've been happy with so far.
Langanobob
« Reply #11 on: May 14, 2011, 07:49:42 AM »
I adapted a TurboCity rack from a Yamaha XT225 to my Monster.  Can't say that it works any better than yours and it sure cost more than $30.   Sounds like you had a very nice trip.
Bob
