November 21, 2024, 04:08:01 AM *
Author Topic: Catless  (Read 4070 times)
arai_speed
« on: May 09, 2011, 09:38:56 AM »
Not my Monster - my truck!!!!
Someone decided they needed it more then I did!
This happened during my lunch work out at the YMCA in La Canana Flintridge.
I called my dealer just to see what it costs new...wait for it....$1650!!!  I'm heading up to the valley in what now sounds like a tank tractor to have an after market unit installed for for $200.
Frustrating!
erkishhorde
« Reply #1 on: May 09, 2011, 01:30:31 PM »
Wait, they took it off your truck during a lunch break? Crazy! Any chance that it fell off?
arai_speed
« Reply #2 on: May 09, 2011, 01:40:41 PM »
Yes - this happened while at the gym.  From the looks of the perfect cuts to the pipes, and being that the oem unit was welded on, it's very unlikely that it fell off.  Unless it fell off while parked and then cat gnomes made of with it.  I guess that's a possibility :-)
derby
« Reply #3 on: May 09, 2011, 06:26:12 PM »
lotsa valuable metal in those things.
-- derby
'07 Suz GSX-R750
orangelion03
My girlfriend loves my
A Most Magnificent Monster
« Reply #4 on: May 10, 2011, 09:40:29 AM »
One would think somebody would have noticed a dude under the truck sawing away...
VIVA LA EVOLUCION!!!
« Reply #5 on: May 10, 2011, 09:51:17 AM »
That sucks, mang.
Pulp Fiction - Don't make the beast with two backs with another man's vehicle
Privateer
« Reply #6 on: May 10, 2011, 04:54:34 PM »
cordless sawzall take it off in short order.  shitty deal man, sorry you had to go through that.
« Reply #7 on: May 11, 2011, 01:47:20 AM »
Fukkin thieves.........................where's BP and the spoons? Angry
hbliam
« Reply #8 on: May 12, 2011, 12:07:14 AM »
Toyota cats are a very common item to be stolen last few years. Thieves get about $50 for them. You sure it was welded on? The cuts look too perfect for someone lying on the ground with a sawzall trying to make a quick getaway. They are usually bolted on. When replaced, mechanics are welding on the new ones, making the bolts hard to get to, and some owners are even fabbing skid plates that cover just the cat.
« Last Edit: May 12, 2011, 12:12:31 AM by hbliam » Logged
The Bearded Duc
a.k.a. duc750
« Reply #9 on: May 12, 2011, 12:27:15 AM »
If you look at the side of the pipe to the right the edges look bent in, exactly like a plumber's pipe cutter would do. Not that I've tried but I'm sure a pipe cutter would make fairly easy work of that exhaust pipe?
2001 M750 - Sold
arai_speed
« Reply #10 on: May 12, 2011, 08:53:58 AM »
Not sure what they used or how it was installed from the factory.  My uncle who is a mechanic for Toyota said thieves use a chain pipe cutter which does the job in no time. Kinda like this:
Like duc750 stated, one of the pipes is/was bent and the edges of the pipes are shiny and metallic as if someone filed them...or in my case cut them off.
hbliam
« Reply #11 on: May 12, 2011, 12:59:12 PM »
That would lead me to believe as you do.
