October 07, 2024, 02:25:41 AM
Mandrel bent exhaust vs weld sections
Topic: Mandrel bent exhaust vs weld sections (Read 9793 times)
May 09, 2011, 12:51:44 PM »
Got into an interesting discussion at work today about how exhaust pipes are made.
Bent vs assembled.
My gut tells me bent is better but trickier. Esp with "soft" metals like Ti.
Thoughts?
TAftonomos
is without a monster :(
Re: Mandrel bent exhaust vs weld sections
May 09, 2011, 01:56:01 PM »
There are limits to how sharply you can bend tube in a mandrel bender, which is why you see some of the cut/welded sections or "pie cuts" out there.
Some of that is simply to show off welding skills.
There is MUCH more potential for problems with the welded method, and it takes a lot of time fitting, and skill welding to make sure the inside of the tube is smooth as well.
There is also a cost factor as well.....I could mock up a complete exhaust system, and have it mandrel bent in one shot. Unfortunately the cost to program, setup, and make one system would be prohibitive, so I buy mandrel bends and cut/fit/section them to work.
MyDucParts.com
Radz
May 11, 2011, 05:50:15 AM »
I would also think that bent is better as you would get a less turbulent flow.
By running a high pressure liquid through the pipe you are bending you can get more extreme bends. (I know that is how they bend the harley v-rod frame)
May 11, 2011, 06:03:41 AM »
Quote from: Radz on May 11, 2011, 05:50:15 AM
yeah, i've read about that method, but i am looking at picking up a mandrel bender... those hight pressure liquid benders are $$$$$$$$$$$$$$$$$$$$$$
DucatiBastard
"Apollonia" '06 S2R 800
May 11, 2011, 06:41:04 PM »
Wow, that sounds similar to "hydroforming" that some car-makers use on their frames (Corvette jumps to mind)
Didn't know that an individual could get a machine to do that, doesn't surprise me that its bank.
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
May 11, 2011, 06:42:32 PM »
Quote from: DucatiBastard on May 11, 2011, 06:41:04 PM
yes an individual can get one, but i didn't see anything less than 7 figures for them.
so that individual would have to be pretty connected.
the regular mandrel benders with cnc I am seeing start around 40k and the NC type start at about 7k
May 11, 2011, 07:42:16 PM »
http://www.vansantent.com/tube_bending_machines/Baileigh150-S.htm
May 11, 2011, 07:46:05 PM »
Quote from: Raux on May 11, 2011, 07:42:16 PM
not a mandrel bender.
May 11, 2011, 07:47:10 PM »
Sharpe Products NISSIN 3D Tube Bender Video
TAftonomos
May 11, 2011, 08:02:57 PM »
A decent mandrel bender starts around 25K, and goes up quickly from there.
Last Edit: May 11, 2011, 08:05:00 PM by TAftonomos
MyDucParts.com
May 11, 2011, 08:17:37 PM »
Quote from: TAftonomos on May 11, 2011, 08:02:57 PM
yeah, i gathered. i didn't see any that cheap though, they were all in the 45k range.
these 6k tube benders -- how do they compare to a proper mandrel bender? from what i've seen, the tube output is pretty good.
TAftonomos
May 11, 2011, 08:42:36 PM »
Not familiar with the ones you are talking about, but I'd venture a guess it's going to kink thin-wall stainless or mild either way.
MyDucParts.com
Langanobob
May 12, 2011, 08:41:53 AM »
The less than $1K die type tubing benders do a reasonably good job on heavier wall DOM tubing. The external dies keep a pretty good form around the tubing OD as it's being bent but I understand that they will do a crappy job on thin wall exhaust tubing.
I've seen some pictures of some nice bends done free hand by packing the tubing very tightly with sand using a threaded ram packing device on the end. Then heat the tubing with a torch and bend it free hand. I think this involves a lot of artistry to get right.
I'm guessing that the lower end (under $1k) non mandrel benders from the likes of JD2, Baleigh and Pro-Tools might work OK with exhaust tubing if it was first packed tightly with sand to hold it's shape while being bent. But this is pure conjecture and I tried Google and didn't find anyone trying it.
I wonder if truckinduc, the kid with the great thread over on the Accessories and Mods board has any thoughts on making exhausts. Haven't seen him post for awhile though.
Bob
May 12, 2011, 09:16:41 AM »
The lower end are called Rotary die benders, but the one I am looking at is a compression bender (EB-300) that is made specifically for exhaust tube -- it's not even close to $1K !
Langanobob
Reply #14 on:
May 12, 2011, 10:58:17 AM »
Quote from: ducatiz on May 12, 2011, 09:16:41 AM
I watched the video link below and there was a drastic change in the tubing cross section in the bend area. Suitable for repairs to a beater pickup truck, but not something I'd want for making a motorcycle exhaust.
http://www.bii1.com/videos/exhaust-bender-video.php
Bob
