New fork springs, 1/4" shorter
Started by seevtsaab, May 11, 2011, 06:39:17 PM
seevtsaab
I've received some S4 fork springs from Nick (thank you) to replace the progressive rate
stockers  in some 06 S2R1K Showa's I'm reworking to replace the Marzocchi's in my 620.
Should I plan to shim the replacements, or can the 1/4" be accounted for via preload?
The Showa's are adjustable.
Thanks.
Bill in OKC
I would try shimming with a few washers (~1/4" worth) and then see how it goes.  I'd guess you would have a better chance of not needing to take it apart again and you have to start somewhere.
EEL
You sure its a 1/4" I didnt this on my m1000 forks and it was more like a 1/2"
corey
You sure the springs dont just "appear" shorter because they are likely stiffer and non-linear?
Typically, a softer spring would appear "longer" than a stiffer one for the same application, right?
EEL
#4
I actually made a new preload spacer instead of shimming with washers. but my distance was a good half inch. BTW I got s4 springs from speeddog too.. you can go to home depot and buy brass drain pipe (1 1/4" 20 gauge) and make your own. Its the same OD as the spacer in your fork.
seevtsaab
EEL  thanks - for the tip. I'll look for some of that pipe or resort to washers (actually closer to 3/8" diff).
Been away, and now I'm having issues getting these installed, what with riding and all.
Cory not quite sure what you're getting at - the stiffer single rate S4 spring is 3/8" shorter than the softer, progressive rate stocker. Ideally I'd have these installed so that  minimum preload  compresses the spring the same amount the springs I removed would be compressed with same preload.
The S4 springs are significantly stiffer than the initial rate of the dual-rate OEM springs you guys had.
Thus, they don't need as much preload to support the same weight at the same sag.
corey
Quote from: Speeddog on May 18, 2011, 09:29:17 AM
this is what i was getting at.
seevtsaab
Think I got it, I just got the first one reassembled last night.
No spacer, so the spring is about 3/8" shorter than the original.
My 'grunt meter' measured a similar grunt factor when compressing the spring, to get to the jamb nut,
as when I dissasembled. Give or take a few squirts of fork oil on ym shirt, doh!
So, despite the shorter spring, there is still 'some' preload built in with preload adjustment backed off.
