Site glass on Left side?
Started by Tdubb, May 12, 2011, 11:34:36 AM
Tdubb
On my 98 750, there is a site glass on the right side for the oil, whats the one on the left side for?
DON'T LET YOUR MEAT LOAF!
Nomad
Flywheel I believe, the dots on it are somewhat useful for lining up your cylinders at top dead center.  Don't worry, it doesn't need to have visible oil in it..
If I'm wrong on anything I'm sure I'll be corrected shortly!
avizpls
that guy is totally wrong.
The one on the right is for oil. The one on the left is so you can see the flywheel. It has marks on it used for setting/confirming the timing and finding TDC. There isnt any oil required to be seen in it, though it will usually splash around some when its running.
#11
Tdubb
Cool, I thought it was a little high to be able to see oil in it. I do however see it splashing around when it's running.
