February 14, 2025, 10:36:06 PM *
Author Topic: Rake/trail on a 696  (Read 1936 times)
Link
« on: May 21, 2011, 09:37:07 AM »
The only spec I can find for the 696 is the rake at 24 deg. but no trail numbers. Does anybody know the rake & trail numbers ?
 Thanks
« Reply #1 on: May 21, 2011, 09:51:56 AM »
Quote
Frame
Chromium-molybdenum tubular trellis frame, cast aluminium
rear subframe
Steering angle (on each side):
32°
Steering head angle:
22.8°
Trail mm:
87
It's in the owners manual...those numbers are for a 2011 696
you can download your year from http://ducati.com/services/maintenance/index.do
i
Link
« Reply #2 on: May 22, 2011, 07:06:11 AM »
Thanks, I was looking for the trail numbers & it's the same 87mm & rake numbers the manual lists "steering head angle" at 22.8. So that doesn't sound like the rake number unless the triples do not have an off-set. Does anybody know if the 696 triples are off set ?
« Reply #3 on: May 22, 2011, 10:35:33 AM »
for sure they are offset. measure the center of the frame nut to the centerline of the fork centers
Link
« Reply #4 on: May 22, 2011, 04:56:34 PM »
I thought of that except trying to get it accurate will be tough. Just so you understand I'm looking for the offset between the top & bottom triple (if there is one) as it's the angle of the forks not the steering head when talking rake & trail. I'm just curious as how the stock rake & trail compare to other sport bikes. If there is no offset on the triple then the 22.8 & 87mm puts it in a pretty good spot as you could change the geometry a fair amount in either direction without pushing the limits of what other bikes are set at.
« Reply #5 on: May 22, 2011, 05:25:17 PM »
Those are the numbers published by the manufacturer.
You looking for a more reliable source? Roll Eyes
« Reply #6 on: May 22, 2011, 08:50:00 PM »
huh? the top adn  bottom triples are the same. they would be bored at an angle if not.
the offset is something like 30mm. I think the superbikes are like 25mm.
