Artful
![](http://ducatimonsterforum.org/Themes/default/images/post/xx.gif) |
« Reply #1 on: May 25, 2011, 11:51:27 AM » |
Noooooo! Back away from the power tools ![Cheesy](http://ducatimonsterforum.org/Smileys/classic/cheesy.gif) That is a wood bit, I couldn't see that ending well. I whole heartedly recommend finding a machine shop in your area with soem epxerienced folks. This a stone simple job for a trained machinist, but easy to botch for a rookie.
Some Dude
« Reply #2 on: May 25, 2011, 11:59:35 AM » |
That tool will grab the aluminum and use the triple to beat the hell out if you. (Like a propeller) If you can't find someone local send me a pm and I can help you.
Bike Info 99 m900s Sbk forks 41mm FCR's Dyna coils 944 hi comp pistons heads ported and polished larger valves new valves and cams aluminum fly wheel & clutch basket
TAftonomos
« Reply #3 on: May 25, 2011, 06:53:45 PM » |
If you choose to ignore the above advice, I will PP you $50 for a video of you using that wood boring bit on your triple clamps.
mookieo2
« Reply #4 on: May 25, 2011, 07:03:22 PM » |
I gave my triple to my local bike shop along with a fork leg and they sent it to their machine Guy for me. It cost me $70.
suzyj
« Reply #5 on: May 25, 2011, 08:10:39 PM » |
Here's the tool I used to machine my top triple: ![](http://farm5.static.flickr.com/4100/4858644898_f127a1bff3.jpg) It's a pretty involved job. You need to send it to a real machine shop.
![](http://farm5.static.flickr.com/4022/4527680818_66f779e144_m.jpg) 2007 Monster 695 with a few mods. 2013 Piaggio Typhoon 50 2 stroke speed demon.
« Reply #6 on: May 25, 2011, 09:06:58 PM » |
dont listen to anyone up there. they are all fools. Taft is the real deal. use the wood thing and film it.
xcaptainxbloodx
« Reply #7 on: May 25, 2011, 09:54:21 PM » |
yes.
uglyducky
something, words, clever . . .
![*](http://ducatimonsterforum.org/Themes/default/images/star.gif) ![*](http://ducatimonsterforum.org/Themes/default/images/star.gif) ![*](http://ducatimonsterforum.org/Themes/default/images/star.gif) ![*](http://ducatimonsterforum.org/Themes/default/images/star.gif)
one way to do this is we can all get naked . . .
« Reply #8 on: May 26, 2011, 11:22:39 AM » |
2008 S4RS - Tricolore #324 (about to get bastardized) 2007 S4RS - pearl/red with some tweaks (sold) 2005 S4R - Bastarda Nera (sold) 2001 M900Sie modded to high holy hell (sold) 2001 996 Biposto - (sold) dirtypunkysocalreggae . . . MANDORiCO
booger
« Reply #9 on: May 26, 2011, 02:37:14 PM » |
and a +2 you've got nothing to fear
2001 M900Sie - sold 2006 S2R1000 - sold 2008 HM1100S - sold 2004 998 FE - $old 2007 S4RT 2007 Vespa LX50 aka "Slowey" 2008 BMW R1200 GSA
tiger_one
« Reply #10 on: May 26, 2011, 02:51:08 PM » |
I imagine you could do it with a hone, just measure often. Me, I'm sticking to the boring bar.
10 MTS 1200 standard 09 M696 (wife's ride)
scduc
« Reply #11 on: May 26, 2011, 02:58:50 PM » |
There are no machine shops in your area? The wood bit thing might work, but I would not risk it. The biggest thing is to make sure everything is rigid. I'd tell ya to send it to me, but you would lose 1 week just in shipping and I would need to know the exact bore diameter.
« Last Edit: May 26, 2011, 03:02:13 PM by scduc »
08' S2R 1K That was close damn near lost a $400 hand cart.
gatorgrizz27
« Reply #12 on: July 16, 2011, 03:01:14 PM » |
Yeah I do have some unusual ideas from time to time, but that has been the basis for this project and so far so good. ![laughingdp](http://ducatimonsterforum.org/Smileys/classic/laughdmf.gif) Honestly I think with a decent drill press vice and feeding it slowly, the worst that would happen would be the bit catching the edge of the slot and either chipping a tooth on the cheapo bit or catching and the belt slipping. Luckily I picked up a mill and a lathe the other week with a ton of tooling so boring bar it will be. Would it be best to remove the bolts and put a washer in the slot, then clamp them down and bore it to 53mm? That should allow the clamp to grab the forks properly I would think.
