December 24, 2024, 05:46:56 AM *
Author Topic: Power band on track  (Read 2704 times)
strat10
I said "What"?
« on: May 31, 2011, 07:50:07 AM »
Had my second track day yesterday on the S4RS, and had a blast. I am finally getting comfortable throwing this beast into a corner, and actually kept up up with my buddy on a Ninja 636, even passing him in a few corners. I did have a question about the powerband on this bike. The track was Willow springs, it has a great mix of long straights and tight corners. My questing is what is the best power range. I was keeping it mostly between 6000-9000. Is that a good range?
thanks
Statler
« Reply #1 on: May 31, 2011, 08:44:41 AM »
There's definately a kick at 6 that doesn't tail off much.
stock ECU or Termi kit?   with the kit it'll hapilly go to 11.
but that range sounds fine....
trackdays are great fun, huh?     if you keep doing them a cheap trackbike is a good alternative to sliding the RS into the gravel.
gm2
« Reply #2 on: May 31, 2011, 11:05:06 AM »
are you sure 'tight corners' was supposed to be plural?  Wink
Like this is the racing, no?
strat10
I said "What"?
« Reply #3 on: May 31, 2011, 01:37:25 PM »
I have full terms on the bike, your saying 11 grand is doable? I thought 10 was the limit, but never did feel the rev limiter.
Workin on a track bike, have to find room in the garage.
Can never have to many corners!
Here I am chasing down the Ninja:
Spidey
Crashin' mofo
« Reply #4 on: May 31, 2011, 01:48:30 PM »
Nice.   waytogo  You're about right on the range, but you can go lower and higher.  I don't know Willows specifically, but the nice thing about a Duc is that you can get low down in the range (even under 5k) and still have it pull.  You can keep it in gear, which sometimes works well in corners where you're trying to carry speed through out the entire thing.  Don't do it all the time, but there's a time n' place.
+bizillion on getting a track bike.
strat10, you want a bit of constructive criticism about that pic?  Feel free to say no.
strat10
I said "What"?
« Reply #5 on: May 31, 2011, 01:56:43 PM »
Quote
i know, I got to get my body off the side of that beast, right?
zooom
« Reply #6 on: May 31, 2011, 03:42:12 PM »
big time...your body position is a ways from where and how it should be...unless you want to slide your bike like Statler did.
2010 KTM 990 SM-T
Statler
« Reply #7 on: May 31, 2011, 03:44:32 PM »
when you feel like you're hanging off like an ape and it must look stupid......   you can hang off a little more and be fine.
lock that outside knee into the tank by pointing your toe/extending your calf.  Put your head where your inside mirror would be.  Open your hips to turn your body through the turn.  Get your chest down and in.
and buy a track bike so while you're doing all that with your knee on the ground at Loudon you don't slide your nice streetbike into the gravel trap outside of the bowl.   Grin
« Last Edit: May 31, 2011, 03:49:14 PM by Statler » Logged
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
« Reply #8 on: May 31, 2011, 03:52:04 PM »
Lol, I love this, great advice all around.
Is this thing on?
gm2
« Reply #9 on: May 31, 2011, 03:53:26 PM »
and get the ball of your foot on the pegs!
strat10
I said "What"?
« Reply #10 on: May 31, 2011, 04:12:42 PM »
all good words from you guys, thanks! I was actually working on leaning off the bike a bit later as I got more comfortable. I definitely DO NOT want to slide my baby into the gravel, that would make me very sad. My buddy did slide it into the gravel right in front of me, definitely a pucker moment. There is a GSXR 750 track bike near me, but there is no room in the garage.
Maybe I should part the 911 outside Smiley
lazylightnin717
« Reply #11 on: May 31, 2011, 04:23:06 PM »
NOOOOOOOO
 bow down
Comes a time
Says don't you see
Gotta' make it somehow
Cider
« Reply #12 on: May 31, 2011, 07:08:38 PM »
Dang, looks like those RSs have pretty good ground clearance.
MadDuck
The anti-
« Reply #13 on: June 01, 2011, 10:42:50 PM »
Go for the Gixxer 750 and park it outside.  laughingdp  You wouldn't be sorry getting the 750 unless it's been thoroughly trashed. Maybe not even then.
tufty
Where did my money go?
« Reply #14 on: June 03, 2011, 04:46:04 PM »
Loads of ground clearance on a Monster, heh.  Wink
