October 07, 2024, 07:19:15 AM
Gas leaking from fuel drain hose [Problem Solved]
Topic: Gas leaking from fuel drain hose [Problem Solved] (Read 5894 times)
hawangatang
June 02, 2011, 07:09:04 PM »
My monster 620ie keeps leaking gas through the fuel drainage hose when i fill up. It happens every time i fill up and i don't overfill or top off at all. In fact, just right now i filled it half way and it still leaks. can anyone tell me if this is a simple fix that i can do at home or do i really have to take it to a mechanic?
everything runs just fine though nothing is wrong with it. no mechanical issues at all. just the fuel draining problem. i mean if it's just a few drops it's fine but i'm talking about drainage. it's kind of embarrassing and not to mention dangerous to stop at a light and my bike is leaking gas.
Last Edit: June 03, 2011, 10:08:06 PM by hawangatang
That which you manifest is before you.
www.hanshcwang.com
2005 Ducati S2R 800 (red)
Re: Gas leaking from fuel drain hose
June 02, 2011, 08:28:34 PM »
Most likely it's one of the rubber hoses that connect from the hardlines in the tank to the filler ring.
May have come unhooked or disintegrated due to sitting in stale gas for a long period of time.
How mechanically inclined are you?
hawangatang
June 02, 2011, 08:44:04 PM »
on a scale of 1-10, 10 being expert... i'm probably a 3. I can do my own oil/oil filter changes, basic engine checks, installing parts etc.
I can take off the filler cap/ring and take a look. what should i be looking for?
thanks speeddog for your help, i really appreciate your prompt response.
www.hanshcwang.com
June 02, 2011, 09:19:17 PM »
There's a set of *very* small set screws that hold the filler ring to the tank.
Remove the filler cap, it's the allen bolts at 12, 5, and 7 O'clock, plus the one under the cap.
See if you've got a metric allen wrench small enough for the set screws....
hawangatang
June 02, 2011, 09:45:12 PM »
yup took everything off, i see that there are two hoses connected to the ring and one of them has indeed deteriorated and has a giant gash in it. I'll replace that tomorrow.
i did however, accidentally drop the bolt under the cap into the tank
don't really know how to get it out anymore...
I just went from a 3 to a 2 on my mechanical inclination scale lol
Last Edit: June 02, 2011, 10:01:23 PM by hawangatang
www.hanshcwang.com
June 02, 2011, 10:17:47 PM »
Try fishing with a magnet. If the screw is steel you could get lucky. If not, either remove the tank or buy a new screw.
hawangatang
June 02, 2011, 10:22:50 PM »
Quote from: howie on June 02, 2011, 10:17:47 PM
unfortunately, i think it's actually stainless steel
i'm going to have to take the tank out and shake it out...
www.hanshcwang.com
June 02, 2011, 10:27:17 PM »
Quote from: hawangatang on June 02, 2011, 10:22:50 PM
See if a magnet sticks to one that didn't fall in the tank..\
hawangatang
June 02, 2011, 10:31:47 PM »
Quote from: howie on June 02, 2011, 10:27:17 PM
yeah it won't stick...
damn...
www.hanshcwang.com
June 03, 2011, 06:40:51 AM »
Quote from: hawangatang on June 02, 2011, 10:31:47 PM
damn...
I'm pretty sure the one small screw under the cap is steel.
The top ones are stainless.
hawangatang
June 03, 2011, 08:33:46 AM »
Quote from: Speeddog on June 03, 2011, 06:40:51 AM
I'll definitely try the magnet fishing again. Thanks so much speeddog.
Quote from: Carbon 14 on June 03, 2011, 06:58:01 AM
You're going to have to suck the gas out and remove the tank to fix the hose anyway. You can get the screw then.
If you know someone that has a boat with an outboard motor/portable tanks you can use the fuel line with the pump ball to drain your tank. You just need to take the QD fitting off the end.
Make sure the replacement fuel (vent) line you install is rated for immersion.
Also a great time to replace your fuel filter.
I'll keep that in mind if I can't fish it out. Thanks a lot guys I'll keep updating.
www.hanshcwang.com
June 03, 2011, 09:04:04 AM »
...and if you don't get the screw out don't sweat it.
It cant hurt anything.
Ddan
Some of my best friends are whores
June 03, 2011, 12:07:57 PM »
I donated a 7mm deep socket to someones tank I was working on, I haven't heard of any problems. I just tell her the rattling is normal valve noise
1992 900 SS,
currently a pile of parts.
Now running
flogged successfully
NHMS 12 customized. Twice. T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
hawangatang
June 03, 2011, 10:06:17 PM »
Problem fixed: like speeddog said it was the deteriorated fuel hose that was the problem. I ended up NOT buying a new hose but just snipping off a part of the original hose and reattaching it. If it ends up deteriorating more then I'm just going to have to buy a new one. Plus it wasn't hard to take off the cap/ring. I just have to be careful not to drop more bolts in there
Thank you guys so much for your help. really appreciate it. I'm going up to Malibu, CA (Rockstore) tomorrow morning around 8 (6/3/2011) hope to see some of you up there as well!
www.hanshcwang.com
