October 07, 2024, 10:39:09 PM
1098 Ohlins forks on an 04 S4R fitment
Topic: 1098 Ohlins forks on an 04 S4R fitment (Read 1034 times)
jjj0923
June 05, 2011, 09:17:57 AM »
I friend of mine has a set of Ohlins forks off a 1098 for sale.
They use the radial calipers.
I haven't measured their diameter but I'm considering putting them on my 04 S4R.
I guess the big issues are
* New triple clamps needed
* New axle?
* New rotors - were the 1098 rotors larger diameter - I believe my srock rotors are 320mm?
* New radial brake calipers
* Are the rotor offsets the same?
or should I just can the idea and go buy a pair of R&T forks from Dan Kyle.
booger
Re: 1098 Ohlins forks on an 04 S4R fitment
June 05, 2011, 02:20:49 PM »
You should shitcan both ideas. The S4R has a badass front end from the factory: excellent valving, linear springs, TiN coated sliders. BAM
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
June 05, 2011, 02:49:37 PM »
yes think you'll need 53/56
* New axle?
yes 1098 axle with spacers most likely custom
-rotors from 1098 are 330mm, but they use a 5mm spacer on the caliper mounts you can remove to run 320mm rotors
- 100mm radial calipers (any new Ducati are running them)
-1098 forks are 15mm offset rotors, not sure of the S4R
