Outer gas cap ring removal 05 S4R-
Started by Radar, June 10, 2011, 08:03:50 PM
Radar
I'm changing gas tanks, 05 S4r, and after removing the actual cap and its ring, followed by removing the 8 very small set screws, I can't get the "outer ring" to budge.
I'm working carefully so as not to damage anything, so I may not be applying enough pressure to lift the ring... I'm assuming there's a large O ring to create a seal, so that may be what's holding me up.
It's in there tight; any suggestions as to how to remove it?  My manual says to simply "pop" it out...
It's in there tight, I tell ya-
Any thoughts?
Thanks,
Eric M.
S4R and stuff-
Put your fingers in the opening, thumbs on the tank, and pry/pull.
Or put a hammer-handle in the opening and pry.
Radar
Hmm...
Same advice from two folks who know what they're talking about.
Thanks Nick and Nate...
I'll do it today.
Eric M.
S4R and stuff-
Radar
Well, I used a handle, just as you suggested, and it popped up without trouble.
Because I've never been inside the tank before, there was a bit of a learning curve, but it turned out to be quite straight forward.
I was able to find a tank in perfect condition, but now I need to paint it, so it looks a bit funny with a blue frame, white wheels and a red tank...  red, white and blue!
The tank turned out to be pretty expensive, so I think I'll ride it the way it is and save up for nice paint.
Anyone want to trade a blue tank with white stripe for a perfect red tank?
Thanks again to Nick and Nate...
Eric M.
S4R and stuff-
I can make it look any way you want. ;D
