Dies @ 120mph..?
Started by Skyshadow, June 14, 2011, 06:00:07 PM
Timmy Tucker
Quote from: Skyshadow on June 15, 2011, 09:53:39 AM
Weird again, I can keep my above 100 with ease. But I only weigh 160lbs... (not saying your fat though man lol)
Yeah, I've got 55-60 lbs on you. I suspect if I get back down to +/- 180 again, the bike will be much happier.
1999 M750 - "Piggy"
2007 S4RS
Skyshadow
(I'm updating this thread instead or starting a new one cause I had good advice coming from you guys)
So Anyways, i learned that my bike will die like it does at 120mph if i go hard on the throttle for longer then about 15 sec. I have been able to temp fix the problem by opening my tank cap and when i do it makes a loud suction noise. Does this still sound like the fuel pump??
- Homemade Exhaust
- K&N filter
- Tail chop w/ integrated tail light
- Sliders
Quote from: cupcake on February 19, 2012, 04:53:56 PM
My rear brake is just for looks.
zarn02
If you're getting a pressure change when you open the tank my guess is that you're looking at a problem with the venting. There should be a vent line keeping pressure inside the tank equal to outside air pressure.
Quote from: Skyshadow on December 04, 2011, 10:34:43 PM
That is definitely a vent problem.
If you no longer have the charcoal canister on your bike, remove the little rubber 'button' from under the gas cap.
Unless the problem is the cap itself that should solve the issue.
Skyshadow
Oh i don't have a canister! man, you guys are effing brilliant... I hope that fixes it! I have a dent from tank slap... you think that would make the beast with two backs with my venting?
- Homemade Exhaust
- K&N filter
- Sliders
Quote from: Skyshadow on December 07, 2011, 06:20:51 PM
Dent shouldn't affect anything but appearance.
Skyshadow
cool, you think that driving it before with the pressure fighting my pump could of messed up my pump?
- Homemade Exhaust
- K&N filter
- Sliders
Quote from: Skyshadow on December 07, 2011, 06:49:27 PM
No clue
jerryz
My M750 will do 108mph at 120 mph on the speedo timed using a Garmin satnav .
Skyshadow
Quote from: jerryz on December 08, 2011, 08:28:06 AM
Good to know and why I'm going to swap out for a R6 gauge cluster and speedo.
- Homemade Exhaust
- K&N filter
- Sliders
Skyshadow
So pulling that little black nipple worked for about 3 days but when my tank started getting low it went back to it's old ways. Thinking of going to a electric fuel pump, any ideas?
- Homemade Exhaust
- K&N filter
- Sliders
WarrenJ
Exactly what mine does - Is your odometer off by about 10% also?
Skyshadow, have you changed the fuel filter?
Quote from: WarrenJ on January 02, 2012, 03:26:18 PM
Seems to be standard error, mine too.
Skyshadow
Yea, twice since I bought it in '09. the current filter has been on it since last summer
- Homemade Exhaust
- K&N filter
- Sliders
Quote from: Skyshadow on January 02, 2012, 02:23:28 PM
Stop driving 120.  [thumbsup]
