Dies @ 120mph..?
Started by Skyshadow, June 14, 2011, 06:00:07 PM
Goat_Herder
or maybe it's your M750 telling you that it doesn't want to go that fast on public roads.  It wants to live long enough to see grand kids someday.
Goat Herder (Tony)
Quote from: Skyshadow on January 02, 2012, 02:23:28 PM
So pulling that little black nipple worked for about 3 days but when my tank started getting low it went back to it's old ways. Thinking of going to a electric fuel pump, any ideas?
It sounds like your vacuum pump is weak/not working.
I think an electric might just solve the problem
Skyshadow
- Homemade Exhaust
- K&N filter
- Tail chop w/ integrated tail light
- Sliders
Quote from: cupcake on February 19, 2012, 04:53:56 PM
My rear brake is just for looks.
Skyshadow
Quote from: ducpainter on January 06, 2012, 04:27:47 PM
That's what I was figuring. What type of pump should i be looking into? I figuring I don't need one that pulls more then just a few PSI.
- Homemade Exhaust
- K&N filter
- Sliders
Quote from: Skyshadow on January 07, 2012, 11:00:02 AM
Something like this...http://www.davesdiscountautoparts.com/item.wws?mfr=BECK/ARNLEY&sku=152-0568&source=GOOGLEBASE
or this...http://www.lbcarco.com/electric-low-pressure-fuel-pump-fuel-filter-and-elements.htm
or you could go to auto-zone and see what they have.
Some people think a low pressure electric pump will cause float needles to leak.
I think 4 gallons of fuel under atmospheric pressure is stronger than 2.5-4.5 psi.
Skyshadow
Either way, As long as the petcock shuts off the fuel, I dont have to worry about leaks.
- Homemade Exhaust
- K&N filter
- Sliders
Quote from: Skyshadow on January 08, 2012, 12:03:43 PM
Petcock is only for when the bike isn't running.
Skyshadow
Soo, I will have to run a fuel regulator?
- Homemade Exhaust
- K&N filter
- Sliders
Quote from: Skyshadow on January 08, 2012, 03:03:06 PM
I don't believe so.
If your float needles are in good condition the 3 ish psi the pump produces is less than than atmospheric pressure.
At least that's my thinking.
Thermite
#39
Gasoline will produce .295 psi per foot of depth.  Quantity of gallons does not matter, just the depth.
Since you don't have a full foot of fuel depth a 3 psi pump will be putting more than 10 times the pressure against the float valves as a gravity system.  Since it already has a fuel pump the floats are designed to stop a certain amount of pressure.  Adding more pressure will overdrive the floats and cause fuel to flow when it shouldn't as DP has said.
The 3 psi rating of the fuel pump includes atmospheric pressure but it makes no difference because atmospheric pressure is exerted against the fuel in the bowls also (14.7 -14.7 = 0).  There are gauges that read in absolute pressure pressure but they are for specialized applications and do not apply here.
Not saying it won't work fine but rather just reporting the physics correctly.
C-14
'07 S4RS and '04 998 Matrix.  Because sometimes I feel like a monster, and sometimes I don't.
Skyshadow
^ I'm not fully sure what your saying here but I believe it means I need a regulator... (Good info though man!)
- Homemade Exhaust
- K&N filter
- Sliders
Thermite
Quote from: Skyshadow on January 08, 2012, 08:37:19 PM
It depends on the output of the original system.  The floats were designed for a specific pressure.  A little less should be okay as they open the needles by losing flotation when the fuel level in the bowl is low.  Too much pressure will force fuel past the needles all of the time.
3 psi is quite low.  I actually think it should be okay.  The part that's missing here is knowing what the output pressure of the vacuum pump should be.
You may be reducing the output of the vacuum pump with the open air box.  If you need to go 120 you may want to consider returning the airbox to OEM spec.
And to those who say you don't need to go 120  [thumbsdown]
Skyshadow
ok, cool. I'm not a fan of the vacuum set up and need to lose it for my next mod anyways so I think I'll go electric with a regulator to be safe.
- Homemade Exhaust
- K&N filter
- Sliders
Quote from: Skyshadow on January 09, 2012, 01:14:37 PM
What pressure are you going to regulate it to?
You don't know for certain that 3 psi is too much...do you? ;D
Skyshadow
No, but from Duccutters i know what pressure i need to do what I'm doing.
- Homemade Exhaust
- K&N filter
- Sliders
