February 11, 2025, 11:55:15 PM *
Author Topic: Red key = will not mobilize "immobilized" bike  (Read 2091 times)
Betlog
« on: June 24, 2011, 03:02:58 PM »
I've done as much research on this as I can and I have found varying reports on whether or not the red key will reset a bike's immobilizer.  So for those who have had first-hand experience?  Will the red key start a bike where the immobilizer has locked it down?
DucsLikeBread
Why not?
« Reply #1 on: June 25, 2011, 01:46:08 PM »
In the manual it say's you need to use the code card to remove the immobalizer. The red key is used to reprogram the black spare keys.
Radar
« Reply #2 on: June 25, 2011, 06:43:20 PM »
Just out of curiosity, how would one go about resetting the immobilizer using the code card?
I don't remember seeing a magnetic strip on mine...
Just wondering...
Thanks.
S4R and stuff-
DucsLikeBread
Why not?
« Reply #3 on: June 25, 2011, 06:56:45 PM »
 You input the code by using the throttle, so if it says six you twist the throttle 6 time's.  Repeat this process with the rest of the numbers.
RichD
« Reply #4 on: June 26, 2011, 08:27:41 AM »
Check the connections for the antenna ring around the keyhole.
Odds are water has gotten into it.
If the transmitter/reciever can't see the key it won't unlock!   Wink
DFW-MFer!
Betlog
« Reply #5 on: June 27, 2011, 10:03:49 AM »
If the immobilizer is tripped, regardless of whether or not you use a valid black key, you would still need to use the electronic code (via throttle).  The question is - if the red key is used, will this be equivalent to using a black key+entering the code WITHOUT having to unlock via throttle inputs?  In other words, if I lost my code card and the immobilizer trips, can I use the red key to unlock the bike rather than black key+throttle inputs?
DucsLikeBread
Why not?
« Reply #6 on: June 27, 2011, 11:52:31 AM »
From what i read in the manual the only way is to use the code card, the red key will not remove the immobilizer.
So if you lost the code card i think you are f****d. There might be another way to remove it and if there is i am sure someone will post it. Sorry i can't be of more help, goodluck with that.
riffraff
« Reply #7 on: June 27, 2011, 12:16:58 PM »
I'm curious, when someone speak of "resetting the immobilizer using the code card," does this mean you--in a sense--start over with virgin gauges, EUC, etc., and go through the red key/black program sequencing.
Or, is the code card trick simply a temporary override?
DucsLikeBread
Why not?
« Reply #8 on: June 27, 2011, 12:46:12 PM »
The gauges and everything else stays just the way they are, the code only has one purpose and that is to remove the immobilizer. It is also like a ID for the bike each bike has there own unique card.
riffraff
« Reply #9 on: June 27, 2011, 01:00:20 PM »
"code only has one purpose and that is to remove the immobilizer."
When you say "remove the immobilizer," you mean permanently remove it, or only for that one time--and only for each time you do the throttle-twist trick?
Betlog
« Reply #10 on: June 27, 2011, 01:10:11 PM »
Ouch.  That would be the answer I don't want to hear.  Can anyone else confirm?
CDawg
S4RS
« Reply #11 on: June 28, 2011, 01:29:49 PM »
its only for that one time.  There are no official ways to permanently disable the immobilizer once the gauge has mated with the ECU.
Grrrly
Industrial Grrrl
« Reply #12 on: June 28, 2011, 01:34:55 PM »
out of curiosity, what year bike is it? and was your bike out in the rain at all?
hunduc
08 S2R1K
« Reply #13 on: June 28, 2011, 02:55:16 PM »
it might be possible that the code can be recovered from ducati by knowing the vin.
Betlog
« Reply #14 on: June 28, 2011, 10:11:48 PM »
The immobilizer has not tripped yet *knock on wood*.  I'm just curious to know if others have been able to unlock a tripped bike with a red key rather than using the throttle code.
