tire wear?
Started by The Architect, June 24, 2011, 05:22:33 PM
The Architect
Anyone ever experience this?
I'm getting a deeper wear pattern at the seams.
One trackday.  28 psi.  80 degree day
Michelin 2ct Power pure.  On my 748.
100_1532 by anzalone22, on Flickr
100_1531 by anzalone22, on Flickr
100_1529 by anzalone22, on Flickr
100_1528 by anzalone22, on Flickr
100_1527 by anzalone22, on Flickr
100_1526 by anzalone22, on Flickr
are you sure you're not part enginerd? [laugh]
The Architect
Quote from: ducpainter on June 24, 2011, 05:30:58 PM
No.  Just don't want to have to buy another tire this season.   [bang]
Quote from: The Architect on June 25, 2011, 04:43:25 AM
Wes is running 25psi on his 2 ct...not sure if it's a power or a pure.
Bruce told him to run 22 but he's scared to.
Maybe too much pressure?.
It sort of looks like the wear pattern on a power near the more transverse tread sipes.
IdZer0
You can always try asking Dave Moss; he's accepting questions via Facebook, Twitter etc.
http://www.youtube.com/user/CatalystReactionSBW
replaced by 2011 848 EVO
Ddan
I was 'encouraged' by a really fast guy at Loudon to be more concerned with hot pressures instead of cold, which does make sense as that's ultimately the pressure you are working with.  His Michelin guy said I should be looking for 33-34 hot on Pilot Powers.  The web is all over the map for pressures on your tires, from 23-30 cold to 34-36 cold, up to over 40 hot.
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: Dan on June 25, 2011, 06:03:56 AM
So...
what pressure should I be looking for on a Power Race 'C' rear and a 'V' front?
hmmmm?
Ddan
Not a clue, but I'll bet you know when it's off   ;D
The Architect
Too much pressure would get me a cold tear.  Not enough would get me rubber flying, balling and a hot tear.  This is neither.  The tire is wearing excessively at the manufacturing seams.  It could also be a cold tear at the seam?
I will drop a pound or two the next trackday and see how it performs.  Also keep track of the hot temp.
Ducvet is going to ask Michelin if this is normal.
I do like the tire.  And would buy it again, so far.  Just have to be VERY, VERY, VERY gentle the first time out they are wiggly!  But quickly change to sticky.
Quote from: The Architect on June 25, 2011, 10:47:52 AM
Is it a Pure or a Power?
Ddan
Quote from: The Architect on June 24, 2011, 05:22:33 PM
The Architect
Quote from: The Architect on June 26, 2011, 04:54:31 AM
Power Pure 2ct
You mean the tire I mistakenly gave you instead of the Power 2ct?  [bang] [laugh]
It's all coming back to me now.
The Architect
Yes.  It was a good mistake.  It's a good tire, I just don't want it to come apart on me.
Did you store it in a barrel of acetone or something like that?   ;D
Ddan
Quote from: The Architect on June 26, 2011, 05:12:48 AM
That should make it pretty sticky, with minimal warm-up needed   [thumbsup]
