m1100 exhaust on an m796?
Started by wannabfast, June 26, 2011, 06:13:28 AM
wannabfast
so i was looking at exhausts, and i saw the zard full exhaust for the 1100, and i was wondering if it would fit
i can see a few potential things that would be different, but im not sure, one would be the height of the heads, which means longer pipes, and the diameter of the ports would probably be significantly larger
any one compare the 2?
the pipes won't line up correctly
the location of the ports is the biggest issue. the sizes are the same afaik
the midpipes of the stock system line up because the front pipes are different. I have an 1100 and 696 and was just comparing them yesterday.
hcomp
Raux,
When in hell did you get an 1100?
にã,,かかã,ã,‰ãšã€ç§ã®è»Šã¯æœ¬å½"に速ã,,ドラã,¤ãƒ–、私は女性のç"Ÿæ®–器のã,ˆã†ãªãƒã,¤ã,¯ã«ä¹—ã,‹
just parts. I'm a collector
[evil] phft phft phft
thought
damn, i was going to ask a question like this too... i keep on seeing some decent deals on used termi full systems, but only for 1100's... was hoping that i could get one and just fit it onto my 796 and then just reflash the ecu.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
Duc796canada
Quote from: thought on June 27, 2011, 09:53:00 AM
http://ducwc.ca/phpBB3/viewtopic.php?f=10&t=2819
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
thought
Quote from: Duc796canada on July 03, 2011, 11:38:27 AM
thanks man, but pretty sure those are just the slip ons, not the full system.
what i was wondering was if the termi m1100 headers would fit on a m796.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
