February 07, 2025, 11:57:41 PM
OZ monsters
Getting suspension sorted
Topic: Getting suspension sorted (Read 2963 times)
CairnsDuc
June 16, 2008, 09:38:38 PM »
G'day All
I have an S2R 800 07, And I'm a heavy guy, so the OEM suspension is struggliing to keep my heavy ass from dragging on the ground, I have been speaking to Dale at Teknik Motorsport in Sydeny about getting my suspension serviced and setup with with the correct springs and valveing, He seems to really know his stuff and has come up with a number of options depending on my budget and what I want to do.
I can find no one up here in Cairns who seems to know what to do, They all just say, bung in some heavier springs and oil and she'll be right.....
I don't think so buddy. I do it right, or I don't do it at all.
So I am wondering has anyone dealt with these Guys? everything I see on the Web reckons they are pretty good, And I have to say Dale has been very good at answering every question and query I have had.
I wanted to see if any of the OZ monsters has any other suggestions or issues.
Thanks
The Don
Re: Getting suspension sorted
June 16, 2008, 10:44:50 PM »
My brother has just had his R6 race bike set up by teknik and he was really pleased, not only did they do the job well but when he went to pick the bike up they ran through everything he needed to know and then asked when he was racing next. I cant remember the name of the fella but he went and met my brother at the track to fine tune his suspension. Not a bad service if you ask me.
Wise men talk because they have something to say; fools talk because they have to say something. - Plato
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
June 16, 2008, 10:59:47 PM »
can you go into further details as to the offered options?
thanks
June 17, 2008, 01:24:54 AM »
Quote from: CairnsDuc on June 16, 2008, 09:38:38 PM
If your 800 runs that same budget forks as my '99 M750, then you're likely being told the right thing. You can't revalve the Marzocci's I've got, the best advice seems to be "put in .9kg springs and 10wt oil, that's as good as they get" - I hear that from Brad Black who I trust as much as anybody.
If I'm right about your forks, your next real option is to start looking for replacement forks. Something adjustable off another Monster is the cheapest/easiest alternative, but they seem to be hard to come by. Forks off most Ducati Superbikes can be made to fit, but we're talking modified triple clamps (shimmed lowers, bored uppers) due to the size differences (and you'd need to ensure you get the right caliper mounts and match the disc offsets too). I hear tales about people fitting GSXR600 and R6 forks, but if you need to ask about a conversion like that it's probably not the sort of job you're up for... If you're made of money, just buy Ohlins and get custom triple clamps and brembo monoblock brakes and trick clutch and brake masters (oh, and get a set for me while you're at it) - that'd set you back something like the price of a good 2nd hand S4RS I suspect...
big
my personal website
my less personal (I'd stop well short of calling it "professional") web site
Spider
June 17, 2008, 01:34:25 AM »
Big,
you are right - they are 43mm non-adjustable Marzocchis.
some of those SBK forks come up on the parts for sale. and they are cheap.
but all that boring, shimming and brake adjustment sounds expensive!
mattyvas
June 17, 2008, 01:54:37 AM »
yeah I went down this road a little while ago.
Was looking at ST2 forks, as I was told that they do fit and it's an easy swap.
I was talking too Jimmy Gunn at Zeno Damper in Caringbah Sydney.
But after much too and fro and then missing the sale of the forks I was not convinced.
Especially that I felt in the end I was going to be wasting money changing forks.
After new tires went on recently my front end feels totally different anyway, much more compliant.
I will still investigate fork oil as a first option then springs after that if needed.
So for me it was the tires that changes the front end.
What are you running, it might make a difference.
I went from stock Pirelli Diablo to Michelin Pilot Power's, massive change.
Hope that helps, a different take on front ends.
cheers
Matty...
My new web home is now at
www.mattvas.com.au
MattyVas Flickr Photos
OzMonsters Flickr Photos
CairnsDuc
June 17, 2008, 02:07:13 AM »
Speaking to Dale at Teknik, This is what he has offered
Front forks
Revalve which includes full clean and service with new Silkolene Oil
Rebound upgrade Kit
$460
Front Springs for my Weight
$180
Rear Shock
Revalve Which includes full clean and service with Silkolene oil
$250
New rear spring
$180
Also for the Rear
Upgrade to Ohlins (Fully Adjustable)
$1050
Rear spring to suit
$180
I asked about the Front fork Rebound Upgrade Kit, He said there Guys fit them all the time to OEM non adjustable Forks. I can just a service and revalve $300 but I decided the rebound upgrade seemed like a good Idea to me. I'm torn between just doing the upgrade to my rear shock or replacing it with the Ohlins
I'm not a hard core rider, I mainly commute with a little cruising around on the weekend, the odd blast up the ranges and overall I am happy with the way suspension feels, I just know it is struggling to haul my heavy ass around, I just want it done right.
CairnsDuc
June 17, 2008, 02:15:31 AM »
Mattyvas, I am running the OEM Battlax, but when I'm braking the forks are bottoming out, a decent bump and I bottom the forks, I spoke to Dale about this and he also agreed just a revalve and oil would not fix this.
But trying to get somebody up here to do even the most basic suspension work is just insane, as soon as most of the guys up here look at them, they see that's a non adjustable fork and they run in the other direction.
I weigh about 115 geared up, The males in my family are big guys, we are not Fat, just built big
(Big boned
Even if I got new forks, I would still have to get them serviced and resprung. So for what I need I think the rebuild of the OEM forks will be my best option.
Spider
June 17, 2008, 02:29:22 AM »
with winter approaching:
could you take the bike in and have forks and shock removed, sent down to Sydney for rebuild?
CairnsDuc
June 17, 2008, 03:08:58 AM »
That's the plan, I'll send the forks down first, Then I'll most likely get the Ohlins for the rear I can get the Ohlins from somebody like Motowheels with the correct spring and save about $400
It doesn't worry me if the bike is off the road for a couple of weeks while the forks are done, It just means the Wife and I will have to share the car while it gets done.
I'm just waiting for my stand to arrive so I can safely lift the front of the bike and store it while the forks are off visiting the Doctor.
mattyvas
June 17, 2008, 03:29:28 AM »
Sounds like a good plan, let's us know the results as I am sure you will.
And if you need anyone to help you with things in Sydney just sing out.
www.mattvas.com.au
CairnsDuc
June 17, 2008, 03:38:41 AM »
No worries, Thanks for the Offer
The more reading I do, I think the Ohlins upgrade will be the best option for the rear, I can order it from overseas from Motowheels with the heavier spring a lot cheaper than I am paying for it in Australia.
I assume fitting a rear Shock assembly will not be difficult
mattyvas
June 17, 2008, 03:41:02 AM »
Yeah I guess so.
But anything that might mean my safety and it goes to the shop.
www.mattvas.com.au
CairnsDuc
June 17, 2008, 01:01:24 PM »
True, But I think If I take this to my dealer I think he's going to be pissed and tell me where to Insert my new Ohlins Shock!!
I might throw a topic into the tech area and see if there are any pitfalls to watch for, Looking at the Parts manual, it all seems pretty straight forward.
Thanks for your help and Information guys, much appreciated, I'll let Dale from Teknik look at the front forks and see what can or can't be done, If they can't be modified like he suggests then I'll start hunting for some SBK forks as suggested and try again. [moto]
Last Edit: June 17, 2008, 01:06:26 PM by CairnsDuc
techno
Reply #14 on:
June 17, 2008, 09:14:00 PM »
Not sure if these will fit or are any better than what you have.....
But they are in your part of the world!
http://cgi.ebay.com.au/ducati-forlks_W0QQitemZ300234437880QQihZ020QQcategoryZ32077QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Quote from: ducmeister on May 24, 2012, 12:45:16 AM
Hey Techno you are a smart man.
Had an accident in Tasmania? -
www.tas-compo-law.com.au
