Buying 2000 monster been sitting for years in OZ ?
Started by jaso1, June 30, 2011, 01:51:30 PM
jaso1
Hi All .
This weekend I'm going to look at and probably buy a monster that hs apparently been sitting for around 5 years having very minimal use .
It as had two new tryes about a month back and some new brake pads fitted .   I'd say the guy has jumped on it occasionally and gone for a quick spin but nothing serious at all .
I thought I would do an oil change on it to start with but can anyone suggest anything else I should look at ?  Say maybe the clutch slave maybe ?    It has had a service and belts changed around 18 months ago to so they should be ok for 6 months by the sounds of it .
I figured if I was to change brake fluid if it looks old-ish I may inadvertently create a problem with the clutch slave so maybe that might just be a replace item for my list ?
Besides obvious stuff , any recomendations ?
cheers
Jason.
Two dogs
Hi Jason
jump over to the Ozmonster section introduce yourself and depending on
where you live someone may be close enough to have a look at the bike with you.
