My darling Monster have gotten all the upgrades it needs to be very close to a true sportbike.
It has been amazingly stable, even at high speed heavy lean angles.
Trail braking - no problem. Small rider input imperfections - no problem.
This all changed dramatically when I made too many changes at once.
Larger tire (5 mm) - 104 links chain raised the eccentric hub ~ 7-10 mm.
My bike was already raised + 5 mm from stock rear and front-lowered 10 mm because of the SpeedyMoto top triple's flat profile.
Reduced wheel inertia uncovered the lack of stability created by these changes.
Added up, the limit for how much a Monster geometry can/should be changed was exceeded.
It felt really nervous at high speed and threw in a couple of nasty wobbles above 120 - 130 mph.
Not confidence inspiring, to put it mildly.
I probably wouldn't have discovered this if I kept the stock wheels, but anyhow I thought I should be able to fix it by working on the geometry and not just cover up my issues with a steering damper.....
I chose to raise the front by whatever much I was able to. (fork legs were flush with the top triple)
They now sit 4 mm below flush level. It looks a bit strange, but not as strange as I first thought.
SpeedyMoto top triples are quite meaty, so there shouldn't be any problems with the reduced fork/triple contact area....
The result was AMAZING.....
I hoped for a signal that I was going in the right direction,
but it was really all that was required to feel safe again.
It's still very willing to fall into turns and cautious rider input is required,
but it's such a great feeling to know that I know my bike well enough to make adjustments that will get me the results I want.
.... and it only took 4 mm
