Interchangable exhaust?
Started by fsx, July 12, 2011, 08:13:52 PM
fsx
Does anyone know if an aftermarket exhaust from an 01 750 with fit an 02 620?
Or what needs to be done to fit it?
If it's just slip-ons it will fit. All double sided swingarm (DSS) monsters can share cans. There are different part numbers on the Ducati fiche - but they all fit up.
fsx
Thanks for the answer.
can you list all the monsters and years that are DSS?  What yr did they start with single swing arms?
Any S*R model is a single swinger and they appeared in 2005. All monsters prior to that can share slip ons.  The 620 and 695, all years as well
erkishhorde
All of the m900s, 620, 675, 750.
COP TZR
does the same apply to the exhaust headers or is this just specific for the mufflers to be interchangeable?
Mufflers only. The headers will be different for the difference engines. 1000 headers will be longer than ones for a 620 for instance, and for an S4 will be set up for two exhaust valves.
Quote from: erkishhorde on July 28, 2011, 11:21:59 PM
All the m1000, 900, 800, 750, 600, 620, 695, S4...
