Break in oil?
Started by meanmonster, July 16, 2011, 11:05:00 AM
meanmonster
I just got my 09 monster 1100S back with a new motor replaced under warranty. The deal used a green synthetic oil for the break in oil. Is that correct? They told me thats what Ducati calls for but I've never heard of breaking a new motor in on synthetic before.
MongoReturns
Yes, I had my dealer triple-check when they replaced my 1098 pistons & cyls.  I'd never heard of it either.
2000Monster750Dark: cored pipes, stage2, 43t, f-18, dptach
2007 1098Red: home depot cooler guard, on sale cluch cover, on sale dp dark tall screen, ebay hugger, hand painted clutch spring caps
meanmonster
Well thanks makes me feel better.
meanmonster
Thank god for parts and labor warranties the whole bill came to like 14,602... Zero out of pocket for me, dealer and ducati were great about getting it fixed ASAP and replacing EVERYTHING.
desmodoktor
Quote from: meanmonster on July 16, 2011, 01:08:33 PM
14 000 $? ? ? ? WOW
IG @desmodoktor & @ridingturtlegarage
meanmonster
Parts: 10,701
Labor: 2,060
Sublet: 197
Other: 12
Tax: 1,232
Total: 14,202
The replaced everything to do with block/head/bottom end. It dropped a valve under power because of a factory defect (part installed wrong).
As long as the oil is moto specific JASO MA I wouldn't worry.
Part installed wrong does not equal "they used the wrong oil."
The green synthetic oil was probably Motul.
Synthetic is fine for break in (it's not likely to noticeably affect how the parts wear together.), it's just kinda spendy for oil that's only going to get abused for 600 miles and then changed.
How many miles before it tried to die?
meanmonster
Ya sorry if I miss communicated. The original motor oem had a factory defect. The new motor is fine I was just verifying that syn was ok oil for break in, which apparently it is. So thank you.
The original factory motor let go at 5100 miles the tech said it's the first new gen monster he's gotten back with a motor blown under warraty but he'd had one 1198 go with the defect (miss installed internal part).
rata911
Green oil? Fully synthetic?
Sounds like Motul 300V stuff. That's good  [thumbsup]
meanmonster
Ya it's green and synthtic. I'll be changing it before 500 miles because I used the "hard" break in method. Looks like the dealer overfilled it a bit also (above the top line).
