Valentine One ... where do I mount ?
Started by S21FOLGORE, July 17, 2011, 03:15:06 PM
S21FOLGORE
I know a lot of people mount their radar detector on the handle bar mount, windscreen, on top of the steering stem.
While I understand that (from the detector's performance point of view) it should be mounted as high & far forward as possible, I want a bit more discreet set up.
Unfortunately, Monster doesn't offer much places to hide V-1. So, I'm thinking, either
1) under the lower triple
(never mind V-1 facing backward. I can be silly sometimes.)
2) right hand side of the frame
As for the remote display ...
1) here
2) or  here
I am also thinking about changing head light, so I may be able to stuff everything in the stock head light location
1) with two eyes ?
1) or one eyed ?
any input?
Monster-Jay
Are those trail tech hid lights?   [coffee]
Nice bike!   [thumbsup]
2011 M796 ABS
MAXdB
how come your stripe is offset? shouldnt it be centered?  ???
Kopfjäger
MAXdB
Quote from: kopfjäger on July 18, 2011, 12:48:23 AM
No
lol.. ok. I was under the impression 2v's are off-center and the 4v's are centered. learn something new everyday..
dubbedown
Although I haven't mounted one on my bike, I'm pretty familiar with the V1 setup and I'd be worried about mounting it so low because 1) road debris which could damage that $400 piece of hardware, and 2) the higher it's mounted the better it'll work. I'd try to find a nice suction mount for the windscreen, or find a nice suction and fab up some kind of mount that'll work.
06 Ducati Monster S2R 800 - wifey
Bitubo damper, Goldlines, Marving midpipe, 14T, CRG LS / Shorty levers, CF rear guard, 3000K HID, Caswell
06 Sport Classic 1000 Mono (one night stand)
Termi CF, DP ECU, DP filter
03 Ducati Monster 620ie (first love)
Termi Ti, PC 3, Open airbox, 14T, SM M3 bar, CRG LS, Pazzo levers, 5000K HID, Cookie1
Magnus
what would happen to that if it got wet?
'02 MS4 Black Fog
battlecry
Not much use having a discreet detector if it doesn't work as well.  My V1 sits on a homemade backet bolted to the clutch side mirror hole.  I use the remote up front with a Mac Parnes LED warning block glued on top.  I also use a fairing to protect it all, with a Really Right Stuff QR block to remove it from the bike.
dont forget that if you ever go on trips, some states make it illegal to own a detector, so it would need to be removed ompletely for you to pass through.
S21FOLGORE
QuoteAre those trail tech hid lights?
Yes, they are.
Quoteroad debris which could damage that $400 piece of hardware,
Yes. The more I thought about all the beating V-1 would take, the more I feel like I should stay away from under the triple mount ...
The windscreen (and fairing, too) is so flimsy ... I can't mount on it.
QuoteNot much use having a discreet detector if it doesn't work
Indeed. So, I guess i am going to either
1)on the (unused) left mirror hole, Techmount sells the mounting kit. (= easy).
2)on the right side of the frame (2nd & 3rd picture), right above ohlins reservoir.
3)Middle of the handle bar. Techmount sells this mount, also.
DarkStaR
Monster-Jay
Re: trail tech hid lights.
Not intending to threadjack, however there are some quirks you should know about those lights that may be of safety concern if you ride at night.
The ballasts in those lights are notoriously sensitive to voltage; in my experience with multiple sets of these lights, the ballasts tend to fail when there is a low voltage condition such as starting your bike with the lights on, at least with the mr11's.  The mr16, variety seem to me more tolerant, however they frequently fail to relight unless power is cycled.  I don't have experience with the larger models, so I can't speak for those.
The trail techs are awesomly bright after 20-30 second of warm up time, however I would never use them as a primary light on the street.  I would definitely buy trail techs again, however I would always consider the possibility of the failure modes above in their use.  Hope you find this helpful!
End threadjack!
2011 M796 ABS
techno
I'm jealous.
Its illegal to even own a radar detector where I live... even if it doesn't work.
damn authority!
Quote from: ducmeister on May 24, 2012, 01:45:16 AM
Hey Techno you are a smart man.  [thumbsup]
Had an accident in Tasmania? - www.tas-compo-law.com.au
S21FOLGORE
OK, so (after a lot of research and rethinking) I've changed my plan. V-1 is going to be mounted on either
1) handlebar center
These are the pic of GPS mount, but you get the idea. I'll use Techmount with 3" extension bar, or RAM mount.
In this location (it would be mounted higher than GPS in these photos), the antenna gets better "view". easy to cover up when getting caught in the unexpected rain or when get pulled over ( just take off the helmet and put it over the V-1).
2) Handle bar right side ( or left )
Probably works just as well (or could be better) as 1) option.
3)right next to the headlight
I need to cut out the fairing (or just give up laser protection.)
4)right side of the frame
1) & 2), I can simply purchase RAM or Techmount. 3) &4) requires fabricating mount.
I'm leaning toward 1) option. What do you guys think ?
And about the head light ...
QuoteThe ballasts in those lights are notoriously sensitive to voltage; in my experience with multiple sets of these lights, the ballasts tend to fail when there is a low voltage condition such as starting your bike with the lights on, at least with the mr11's.  The mr16, variety seem to me more tolerant, however they frequently fail to relight unless power is cycled.
I was aware of this. So, my solution is that I'm going to put a on/off switch (somewhere hidden), when ignition is turned on, the light is off. After starting the engine, I'd turn on the light. What do you think?
wow that's a lot of trouble to avoid a speeding ticket.
