February 11, 2025, 09:36:22 PM *
Pages: [1] 2   Go Down
Author Topic: Monster 696 rear tire replacement  (Read 10489 times)
chocobo15
« on: July 19, 2011, 08:11:22 AM »
Hey guys, need some quick advice for tire replacement. The stock tire is 160/60/17, but I called some local shops and some of them seem to think that that size is abnormally small.
I can't seem to justify that since it was a decision made by Ducati, so I'm assuming it would be in the best interest of the bike, but i need to hear it from you guys! For those of you who have replaced tires, what have you done? one shop recommended that I go up to 180/60/17 dual compound tire.
what do you guys say? how much should a replacement tire cost?
thanks in advanced
Omnipotent Potentate
Personal Pretext
« Reply #1 on: July 19, 2011, 08:28:29 AM »
They manufacturers specs should be followed.
The 696 is spec'd to take a 180/55 as well as the 160/60... But the bigger tire will have more mass. More mass=more power needed to get it going and change it's direction.
Why do they think that's abnormally small? The base level monsters have had more narrow tires (and wheels) than the rest of the monster line from the get go.
chocobo15
« Reply #2 on: July 19, 2011, 08:36:05 AM »
i have a feeling that one shop did not know what they were talking about. The other shops who told me they thought the tires were small never worked on ducati's before
« Reply #3 on: July 19, 2011, 08:37:05 AM »
the 160 spec tire allows quicker turn in, handles the power to the ground without spinning and is lighter.
to go to the 180 you'll need a new rim and not sure if there is an issue with chain clearance needing the sprocket reversed in the front. people have done it here, search for 696 180 tire swap and Ducati performance rims for 696. I also think someone threw on a St2 rim.
The idea that it's abnormally small... leads me to believe their knowledge of a Ducati Monster is abnormally small.
chocobo15
« Reply #4 on: July 19, 2011, 08:38:00 AM »
any recommendations on tires? so far i have michelin pilot power 2cts as a recommendation
« Reply #5 on: July 19, 2011, 08:40:05 AM »
depends on your riding and budget requirements.
do you commute?
do you live in a rainy environment?
do you do track time?
do you push it to the limit in the twisties?
do you want a tire that lasts miles?
can you purchase replacements often?
Personal Pretext
« Reply #6 on: July 19, 2011, 08:47:56 AM »
Are you replacing both front and rear? Or just the rear?
« Reply #7 on: July 19, 2011, 08:49:58 AM »
good point, don't mix and match.
chocobo15
« Reply #8 on: July 19, 2011, 08:51:12 AM »
mostly commuting riding (60 miles a day to and from work ... freeway miles)
i live in so cal, so no rainy condition
i dont do anything crazy, but i do take on the cayons every now and then
A dealership told me to get a bt016, anyone experienced with that?
« Reply #9 on: July 19, 2011, 09:05:54 AM »
if you want to change your tire often... sure, bet they handle great, but a pure sport tire with your 60mi commute will square off quickly.
you definitely want to look into a sport touring tire preferable dual compound to handl the canyons as well as the commute
I have the same issue. I live in the hills but my commute to work is 44km one way on highway. I have the Michelin Pilot Road 2CT and they can handle everything well. a lot more confident in the rain than with my stock Battleax tires and they are not squaring as quickly.
But there are other brands of dual compound out there if you want to keep looking.
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
« Reply #10 on: July 19, 2011, 09:18:54 AM »
+1 on the 2ct
I've had mine for 2 weeks now and they feel confident.
But them online and bring them into the shop.
Is this thing on?
Personal Pretext
« Reply #11 on: July 19, 2011, 09:41:34 AM »
Find the sport tour equivalent of your front tire if you're not planning to replace the front as well. Mixing and matching brands usually ends in tears - or at least a oddly/crapply handling bike
sbricon
« Reply #12 on: July 19, 2011, 11:54:59 AM »
I just replaced my tires with a set of Metzelers Interact M5 ...They are great. They are sticky and great feel in yeh rain.  I have already put 2000k on them and they are a big improvment from the Bridgestone.
Avanti Sempre!!!
« Reply #13 on: July 19, 2011, 02:07:38 PM »
180s are kept in stock, 160s not so much.  Tire and rim are not compatible, your rim is too narrow.  And everyone is correct about the handling.  This is like a shoe salesman selling you a pair of shoes one size too large and telling you to wear two pair of socks.
Veloce-Fino
Wiggle-Jiggle
« Reply #14 on: July 19, 2011, 04:28:34 PM »
Knew I shouldn't have bought those shoes..
Is this thing on?
Pages: [1] 2   Go Up
