February 15, 2025, 03:11:25 PM
PCIII no bueno?
Topic: PCIII no bueno? (Read 2730 times)
uglyducky
something, words, clever . . .
one way to do this is we can all get naked . . .
PCIII no bueno?
July 23, 2011, 06:16:01 PM »
pulled the pcIII off the bike today for a rough comparison (to try with just stock ecu) as i'm kicking around the sale of the bike. i gotta say the power curve wasn't quite as vicious but the bike ran from idle to 5k a million times smoother and low (under 20%) throttle cruising was impeccable .. .. sooooo, what's the deal? i don't think i'll ever use one again.
2001 996 Biposto - (sold)
Feral 859
Re: PCIII no bueno?
July 23, 2011, 06:35:35 PM »
Was it mapped on a Dyno?
uglyducky
Re: PCIII no bueno?
July 23, 2011, 07:09:32 PM »
Quote from: kopfjäger on July 23, 2011, 06:35:35 PM
only 4 times in the past 6 weeks
DarkStaR
Re: PCIII no bueno?
July 23, 2011, 09:17:24 PM »
Did you ever have any suspicion that is was not running well while it was on? Just wondering.
Do you have the Dyno printouts? I'd be curious to see what they look like.
With the air in & out mods, I wouldn't be able to ride the bike with out the PC3...it just runs shitty without it.
muskrat
Re: PCIII no bueno?
July 23, 2011, 09:44:26 PM »
Interesting because I never had a problem. I'm guessing the tune sucked
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
uglyducky
Re: PCIII no bueno?
July 23, 2011, 09:47:56 PM »
Quote from: DarkStaR on July 23, 2011, 09:17:24 PM
not specifically, just heard from a few folks that before doing any dyno work they like to see how the bike runs with existing ecu solo. it is only at cruising below 5k in a few spots that the bike is unhappy. lemme see if i can get speeddog to email me the map. he's got it at the shop. acceleration and higher throttle cruising is epic with the pc3 but i just can't justify the low end idiosyncrasies enough to wanna use it
uglyducky
Re: PCIII no bueno?
July 23, 2011, 09:48:51 PM »
Quote from: muskrat on July 23, 2011, 09:44:26 PM
stock ecu? pipes/airbox setup?
DarkStaR
Re: PCIII no bueno?
July 23, 2011, 11:08:34 PM »
Unfortunately the PC3 is just a passive signal altering device. It has to be told when, where, and how to alter the injector signals.
There are 3 factors that I can currently think of that may cause issues similar to yours:
1) If the map was tuned properly, something on the bike is not the same as when it was tuned for one reason or another.
2) The map sucks. Might or might not be due to the tech that tuned it, could just be other bad conditions during the tuning.
3) Haven't heard of this yet, but maybe that unit is defective.
But, if you had it on the dyno 4 times...was the tech the same person? Was it the same machine? Were the cylinders tuned individually?
There are some bikes that are REALLY hard to map properly (MV Agustas), but haven't heard of a Duc being that difficult to map.
For the more technical peeps out there, as the PC3 reads a signal from the TPS, if the bike was mapped, and then the TPS is reset, would that affect the map enough to be noticeable?
Last Edit: July 23, 2011, 11:22:17 PM by DarkStaR
Feral 859
Re: PCIII no bueno?
July 23, 2011, 11:39:58 PM »
Quote from: uglyducky on July 23, 2011, 07:09:32 PM
bummer
muskrat
Re: PCIII no bueno?
July 24, 2011, 08:18:24 AM »
Quote from: uglyducky on July 23, 2011, 09:48:51 PM
stock ECU on both bikes running (one previous) after-market exhaust. I've always used the Marvin mid pipes. My guy tunes all my bikes and I've never had a problem, include my POS Hog.
In my experience all Ducs run like shit under 3k rpm or below 45 mph. They like to be revved.
2015 MTS 1200
09 Electra Glide
uglyducky
Re: PCIII no bueno?
July 24, 2011, 09:52:12 AM »
ya, i don't know but splitting lanes with your bike is coughing is a bit sketchy
- i really prefer the bike without the pc3 but IF i sell it (still struggling with pulling the trigger) i will include the unit and custom map made for the bike. it was indeed the same dyno tech and owner of his shop. i'm not saying he's a ninja but he's no slouch either. but, anything is possible i guess. we'll see, for now sans power commander the bike runs the best in small throttle - so i'll leave it as such. however, there is a slight decrease in 'oompppfff' over 4-5k
BlackKat
Re: PCIII no bueno?
July 24, 2011, 10:40:33 AM »
Two note-able points:
I warranty quite a few defective power commanders...Dynojet is really effin great about them though...generally, no questions asked and I have a new one in my hands in a reasonable time frame...
ALSO, Granted, with a dyno in house, I see a ton of different makes and models in for custom mapping. In general, we have seen multiple Ducati bikes with poor low end performance, even unsteady idling if not paired with the DP ECU...I don't recall similar problems with any other brand that has performance ecus available or performance mapping from the respective manufacturer (i.e., Triumph for example)
Just a few things I've seen.
muskrat
Re: PCIII no bueno?
July 24, 2011, 12:33:10 PM »
My Tech has said the same things as stated above. It's really a shame that sometimes you can't get around that pricey DP ECU.
2015 MTS 1200
09 Electra Glide
uglyducky
Re: PCIII no bueno?
July 24, 2011, 12:54:10 PM »
i have a custom reflashed ecu on the way from houston superbikes. i'll see what the story is as far as how it does/does not help the equation. should be even better than dp ecu as it is programmed for precisely the setup on the bike (arrows, k&n, open box, etc)
bikepilot
Re: PCIII no bueno?
Reply #14 on:
July 24, 2011, 01:47:47 PM »
I'll second what darkstar said, blaming a PCIII for poor running is like blaming the computer for a lousy term paper. All it does is allow you to alter the fuel mapping, its up to you do develop a good map (assuming the PCIII isn't defective, which I doubt from your symptoms). Dynotuners somewhat often focus only on WOT and higher rpms to develop pretty graphs but fail to really dial in partial throttle and lower rpms all that well.
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
