February 19, 2025, 01:46:05 AM *
Author Topic: 848/1098 brake line with S2R1000/S4R gold line master cylinder  (Read 1776 times)
csorin
« on: August 02, 2011, 12:43:45 PM »
I'm looking at overhauling my 620's front end and gathering the last of the bits needed for the superbike conversion.  I have a set of goldline master cylinders from an S4R, and would like to change out the brake lines for a better fitting superbike set.  Are the 848/1098 brake lines compatible with the goldline masters?  Is a different banjo needed at the master?  I understand I'll have to get a double banjo for the right caliper.  Thanks.
« Reply #1 on: August 02, 2011, 12:49:08 PM »
i'm running the goldlines with 848 forks and I think a 916 front line. it's too long. so I may be looking for the 848 line as well. the lines are pretty much interchangeable. the 848 runs one line from the master and a crossover line i think
« Reply #2 on: August 02, 2011, 01:48:35 PM »
848/1098 have radial master cylinder and radial calipers.
Radial master, the banjo bolt goes up from the bottom.
Radial caliper, the banjo bolt is at a slightly different orientation than on axial calipers.
May not work well with your goldline master...... and.....
What calipers are you going to use?
csorin
« Reply #3 on: August 02, 2011, 02:00:30 PM »
My '04 620 has the original dual 320mm gold line calipers.
When you say 'may not work well', do you mean the length will not be correct at the calipers?  What would be the problem at the master?
DarkStaR
« Reply #4 on: August 02, 2011, 05:00:35 PM »
...What would be the problem at the master?
« Reply #5 on: August 02, 2011, 05:25:35 PM »
The OEM brake line your bike came with is the best fit for regular bars.
If you're going clip-ons, a 748/916/996 line will likely work.
csorin
« Reply #6 on: August 02, 2011, 06:32:13 PM »
Cool, I'll keep my eyes out for a 916 setup.  It looks like Gotham Cycles offers the lines for 25 bucks.
I saw Spiegler and Galfer offer brake line kits for the 916/996 series bikes.  Spieglers are a little pricier, but have more color options.
The two companies also offer an alternative to the single line with a dual-line setup coming off of the master.  Would an extended banjo bolt cause any clearance issues?  This setup is $60 cheaper than the standard single to split routing.  What am I losing/gaining by going with two lines?
« Reply #7 on: August 02, 2011, 08:00:33 PM »
Regular bars?
Suburban Machinery bars?
Clip-ons?
If so, above triple, below triple?
csorin
« Reply #8 on: August 03, 2011, 05:37:01 AM »
Regular bars?
Clip-ons?
Speedymoto no-rise clip-ons (not the tall-boys)
Quote
Below triple
DarkStaR
« Reply #9 on: August 03, 2011, 07:55:34 AM »
From what I've experienced, you "may" run into double master banjo interference issues with the following:
1) Gauges,
2) Fairing mount tabs, and/or
3) Headlight brackets.
Depending on if you have lowered your gauges, and how you bolt everything up,...YMMV
Some will say they can notice a difference in feel depending on the set up, and/or bla bla bla
It's an aesthetic personal preference in my opinion.
« Last Edit: August 03, 2011, 08:03:01 AM by DarkStaR » Logged
