January 08, 2025, 12:18:08 PM *
Author Topic: How NOT to install clip-ons  (Read 2263 times)
johnster
« on: June 18, 2008, 05:33:26 AM »
So my Apex clip-ons + CycleCat adapters came yesterday for my S4, and I decided to frenetically try and install them before the Celtics Championship game started (2 hours from the beginning of installation....  Undecided)
-1st things 1st...  drink drink drink drink (that seems to be a reliable way to make the beast with two backs up whatever it is you're doing).
-So all I had to remove/reinstall the mounting hardware was one of those cheesy fold-out multi-size hex keys and most of the bolts were factory torqued to WAY beyond what this stupid thing could handle, so I used a "cheater bar" to try and get them loose... Big Mistake..  bang head
-I ended up stripping the heads of 90% of the mounting hardware, and very smartly used the SAME bolts (with Loctite) to fasten everything down because I was in a half-drunken rush.. God help me if I ever have to take them off!!   Roll Eyes Due to the absence of a torque wrench, I just cranked the nuts out of each bolt until it wouldn't turn anymore..
-I inspected the damage this morning and the actual install doesn't look that bad, but most of the hex heads are hopelessly rounded out..  Angry bang head Has anyone had luck using Easy-Outs or removing bolts that are torqued down really hard??
-I will post pics when I get a chance (maybe tonight), But the moral of the story is to watch your alcohol intake prior to wrenching on your bike!! Obviously having a few beers and working on the bike is fun, but once you get that "Ahhh screw it" attitude you'll likely do more damage than modding!! I remember someone here who didn't tighten the rear axle nut on their S2R and make the beast with two backsed up their rim...I feel your pain!!!  Embarrassed
-Oh, and to top it all off the Matris steering damper I just mounted 2 weeks ago doesn't fit now... I need to find a side-mount bracket.... Uggghhh... Sorry, I just needed to vent..
« Last Edit: June 18, 2008, 05:46:49 AM by Johnster » Logged
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
« Reply #1 on: June 18, 2008, 07:02:14 AM »
Get yourself an impact driver to remove the stripped out screws. Its a tool that you insert a bit into (hex socket) and hit with a hammer. It should take em right out. Don't use easy outs.
derby
« Reply #2 on: June 18, 2008, 07:16:48 AM »
also, pinch bolts don't have to be "cranked down."
-- derby
'07 Suz GSX-R750
johnster
« Reply #3 on: June 18, 2008, 07:19:08 AM »
Yeah, it was more the adapters that attached to the triple that I cranked down... Luckily I maintained some common sense and realized that the threads on the pinch bolts could be damaged if tightened too much...
Grappa
« Reply #4 on: June 18, 2008, 09:19:32 AM »
I prefer to wait until I am done working on the bike, then celebrate with a nice  drink.   Or if I have already been drinking, cleaning the bike can be fun, but no maintenance.
Ahh... but the servant waits, while the master baits.
Sometimes Aloha means Goodbye.
For $50 you can touch my
« Reply #5 on: June 18, 2008, 11:11:31 AM »
http://ducatimonsterforum.org/index.php?topic=292.0  Wink
herm
« Reply #6 on: June 18, 2008, 04:19:24 PM »
on the positive side....the celtics won #17 waytogo
'05 620ie
« Reply #7 on: June 19, 2008, 11:36:37 AM »
 laughingdp laughingdp laughingdp
Duc L'Smart
« Reply #8 on: June 19, 2008, 11:44:13 AM »
Sounds like the torque-wrench monkey in the factory in Italy won Tongue
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
cbartlett419
« Reply #9 on: June 19, 2008, 03:03:36 PM »
if you heat the bolts w/ a soldering iron the loctite will loosen
