School me on Jeep Cherokees
Started by ducatiz, August 12, 2011, 12:51:35 PM
I want a Jeep Cherokee.  Not a Grand Cherokee, not a Liberty, not a Wrangler.  I like the way they look and the AMC engine they use.
I know there are different generations of that I6.  I am looking at 99 and up models.  I don't have specific questions except which years and engines should I watch out for and how do these engines fare?  I am seeing 99-2000 models with 200k miles on them (!).
I'd prefer a stick with 4x4.  Seems most of them are 4x4 but not many stick.
fastwin
My current wife and her ex had one in the era. If I remember right they really liked it. I'm IZ_ on details since it was sort of before my time. I know it was an auto. Wifely unit doesn't do a stick. Yeah, that's right... I said it that way on purpose! [laugh] Late afternoon entertainment. ;D I bet most of them will be autos. I can see manuals being few and far between. I'm on pretty good terms with her ex, I'll ask him about it next time I see him.
Stella
Quote from: Stella on August 12, 2011, 02:52:22 PM
Derby
http://www.ducatimonsterforum.org/index.php?topic=48032.0
That's on jeeps in general.  I'm looking for specific info on the Cherokees.. i.e. engine, fueling, electrical etc
DW
Jeepforum.com. Consensus is the '99 is best. Strongest engine and also upgraded rear axle. I may be biased, I own one
Quote from: DW on August 12, 2011, 03:51:13 PM
The 99 has a better axle than the later years?
I assume the engine output is related to emissions limitations?
I googled the 99 model and they have a 4-cylinder model too?  What motor is that?
DW
Quote from: ducatiz on August 12, 2011, 03:52:42 PM
Backwards actually. The '99 on received a stronger Chrysler rear axle, but mid 2000 they changed the head design. Output is the same, but the 2000-01 head is prone to cracking. Look up the XJ section at jeepforum for all the answers you could want.
Hence the '99 is the best of bthe old cOmbined with the best of the new.  Also axles change based upon abs as an option. Tons of configurations.
El Matador
Expect to change electric window motors. CONSTANTLY.
Other than being really light on the rear and prone to skidding in the wet, they're uber solid.
They also have a particular smell that can only be described as the Cherokee smell. Every single one I've been in has it.
Stella
Quote from: ducatiz on August 12, 2011, 03:37:40 PM
The convo in the prior thread covered a bit of what you were originally looking for.
Re:  engines, fueling, electrical, etc. - yes, jeepforum is the place for that.  (Also www.cherokeeforum.com)
My '99 is still holding strong at 277k - original engine.  No electrical issues other than a one-time
window motor fail that we fixed at home with minimal effort.
Can't say it has any particular smell that I ever noticed nor has anyone brought it to my attention.
Maybe I'm used to it after so many miles?!   If anything, it smells like Armor All.   [thumbsup]
Good luck w/your search!
Mother
It's from the off gasing of the plastic interior or so the theory goes
Avoid the peugoet(sp) transmission
You WILL replace the header often
On the I6 At 250,000 miles you should consider changing the timing chain
On the 258's you will want to change out the plastic valve cover
found my old skin suit
DW
[quote
[/quote]
That's funny. Mine smells like sweaty mountain bike gear. Pretty much overwhelms everything else...
ducrider45
Lift kits for the Cherokee sports are fairly cheap as well. There is lots of aftermarket stuff for them as well. I'm considering building one as well.
Thomas Jefferson
I'm not interested in modding it too much.  I originally got interested because the early models had a Renault diesel in them.  I see them pop up every once in a while.  The look has grown on me and a girl in my office has one which she's let me drive and I rather like it.
I had a Ranger for a truck and it died, and I've been thinking maybe a ute would be better, esp since I have a trailer for when I need a truck bed.
A.duc.H.duc.
You don't want a 99 and up, you want a 98. In 99 they changed the head design. Smaller exhaust ports to decrease emissions. The new casting is prone to warping when it gets hot, and Cherokees have a tendency to get hot.
Justin
DW
Quote from: A.duc.H.duc. on August 12, 2011, 09:41:49 PM
Justin
Reference above, '99 still has the old head design.
