Project 900SS/SP refresh
Started by TAftonomos, August 13, 2011, 10:39:35 AM
Great work. Nice detail touches.
TAftonomos
They are about an inch away, and yes it's something I need to address.  I'm going to pick up some 15 degree ends and see if that helps.  Nothing really to tie them back on down there  :(
corey
Quote from: TAftonomos on March 02, 2012, 06:07:26 AM
Crap... i'm not so sure 15° bends are going to help much, and they might be just enough to give you a clearance problem with that starter, right? I'm going to look for some more solutions. At $3 each, I'm not to concerned with having a couple extra straight swivel seal fititngs laying around ;D
corey
so after a bit of looking around, i ran into this image.
it looks like we can tuck them back far enough. i asked this bikes owner, and he's had no issues. all things considered, that area of the bike gets a good amount of air while moving. if you're ceramic coating your pipes (which i am not), then you should have even less to worry about.
check out these little wire brackets he has (my bike has it as well). i think this is the ticket.
also, i noticed the two bolt holes on the engine/head there, one on each side. might be able to fab up a line holder out of something that mounts in one of those holes that keeps the lines close to the starter.
looking around at fittings and whatnot, i think the 60° fittings that aeroquip has MIGHT work... but they clock in at $20/per, so I'm willing to give it a shot without them first. aside from that, no other real options unless you put in an inverted-flare hardline with a custom 90° bend... but then you've got a metric-to-AN adapter, followed by an AN-to-InvertedFlare adapter, followed by inverted flare hardline, followed by InverterFlare-to-AN adapter, followed by AN-6 fitting... too many potential leaky spots for my comfort level... plus it'll look ridiculous...
TAftonomos
That looks like it will work great Corey, thanks!
Quote from: corey on March 02, 2012, 02:26:53 PM
That is where the side-fairing supports screw in on the full faired SS
corey
Quote from: ducatiz on March 04, 2012, 07:17:08 PM
gotcha. my bike probably doesn't have them at all then...
Quote from: corey on March 05, 2012, 05:45:00 AM
i think all the 900s do.  it is in the cylinder casting. just a blind threaded hole, M8
