February 11, 2025, 09:58:35 PM *
Author Topic: 695/620 parts interchangeability  (Read 2639 times)
dark_duc
2008 S4RS Tricolore
« on: August 17, 2011, 07:55:28 PM »
Sorry if this has been asked before, but I am looking for a red front fender and seat cowl for my '06 620.  I found a red fender in good shape on ebay for an '07 695.  Am I correct in assuming these parts are interchangeable?  Would that also go for the seat cowl and wind screen?  I think they are but wanted to be sure before I buy.
Also, anyone happen to know if the solid red color changed at all between '05 - '07?  I have a red '05 tank for a 620 and was hoping the above mentioned fender would match.
Thanks for the help  Cool
zarn02
« Reply #1 on: August 17, 2011, 09:47:34 PM »
I can't find a part number for a 695 seat cowl, so I don't know. The 620 cowl is 595.1.025.1B[A,B,C,D,G,I,L, depending on color].
The part number for the front fenders is the exact same, so it should work just fine.
dark_duc
2008 S4RS Tricolore
« Reply #2 on: August 18, 2011, 03:15:17 AM »
Excellent, thanks!
Omnipotent Potentate
Personal Pretext
« Reply #3 on: August 18, 2011, 04:50:10 AM »
99% of parts can go from or to a 695 from a 620. It's only some internal engine bits and electronic gear that wont' match up. Everything else is same same.
Betty
« Reply #4 on: August 18, 2011, 11:20:05 AM »
I am not sure if this is market specific ... but the early 620s came with a metal tank and 4 piston calipers with 320 rotors. At some point the tank changed to plastic and the smaller brakes were used like the 695.
EDIT: Oh, and the 620 (at least the earlier ones) was 5-speed without the APTC (that may be part of the internal bits SP was talking about)
« Last Edit: August 18, 2011, 11:28:22 AM by Betty » Logged
Personal Pretext
« Reply #5 on: August 19, 2011, 04:38:43 AM »
There was also a 6 speed w/o the APTC as well.
But since we're just talking fenders and bolt ons I figured i wouldn't go into all the phased changes during the 620s run
Betty
« Reply #6 on: August 20, 2011, 12:22:42 PM »
All good ... it was your "Everything else is same same" comment after mentioning internal and electronic bits that had me worried.
Just wanted to avoid mis-interpretation.
nikkimonster
« Reply #7 on: August 20, 2011, 07:12:11 PM »
what about exhaust interchangeable? since the low slip-on low mount termi for 620 are discontinued, i was wondering if i could get the low mount set for the 695, keep the termi and air filter, then sell the ecu whiich i know for sure does not work on the 620.
d3vi@nt
« Reply #8 on: August 21, 2011, 08:08:55 AM »
I have an '07 695 and can confirm that they didn't come stock with a cowl. However, I found one on e-bay (p/n 595.3.025.1A) that was off a '98 M900.  The red color matched perfectly and it fit perfectly, as well.
'13 MTS GT
'99 ST2
'07 M695 - Sold
bikepilot
« Reply #9 on: August 22, 2011, 07:17:23 AM »
I parked next to a 695 a few days ago, exhaust looked identical to me.  I didn't take measurements, but there sure aren't any major differences and I'd be very surprised if 620 and 695 cans weren't interchangeable.
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
Personal Pretext
« Reply #10 on: August 22, 2011, 09:02:24 AM »
Slip-ons for all the DSS monsters from 2000 (at least) and on will exchange
Blackout
« Reply #11 on: August 22, 2011, 11:58:11 AM »
?for future reference, does anyone know if a 1000DS engine will fit into an 800 frame?  popcorn
2003 Ducati Monster 800
2003 Honda CR250
2008 KTM 990 SuperDuke
Personal Pretext
« Reply #12 on: August 22, 2011, 12:09:05 PM »
Pretty sure any similar year air cooled will drop into another frame. There might be a bracket to two that's different, but the engine mounts should be same same. One thing to investigate would be the placement for the coils on the single vs dual spark and what goes on with that. Going well back there used to be smaller mounts - where sliders are usually placed but that got changed out in the early 2000s.
As you might figure - a water cooled engine won't go in so easily.
