February 19, 2025, 02:36:32 AM *
Author Topic: Lowering Gauges; Upper Triple Bracket Pin Removal  (Read 1804 times)
csorin
« on: August 18, 2011, 01:21:40 PM »
Hey guys.  Sending off my U-Bracket for Taft's welding magic, and in the meantime I've been looking at all the 'headlight lowering' threads.  Seems some people leave the upper triple pins in place and others remove them.
I have a Speedymoto top triple on the bike right now, and its pins are in there solid.  Does anyone have suggestions on how to successfully remove these pins?  If not, alternate methods of mounting gauges below the triple?
Artful
I'm glad they make pills for my
« Reply #1 on: August 18, 2011, 01:37:42 PM »
The pins in the SM triple are just interference fit in there. You'll need a large pair of pliers to crush them just slightly and then pull them out. You'll want to put the upper triple in a vise, being careful not to scratch the surface. They won't come out without a fight. PB Blaster is your friend.
Duc Buz
Bad Cop, No Duc
« Reply #2 on: August 18, 2011, 04:06:18 PM »
Artful is right on, they ain't easy.
11B4P (Ret) US Army
2003 620 Dark (Matte Silver)
DucNaked
« Reply #3 on: August 18, 2011, 05:12:52 PM »
I locked the pins in a vice and spun the triple. They came right out.
DarkStaR
« Reply #4 on: August 18, 2011, 07:09:02 PM »
Find the correct screw (m5 i think), screw them in from the top, and that'll push the pin out the bottom.  Easy.
csorin
« Reply #5 on: August 18, 2011, 07:17:33 PM »
Good lord this way sounds easy...
Just spent a good ten minutes pulling my hardest on the things.  They are certainly in there.  Methinks I need to invest in a vice.
« Reply #6 on: August 18, 2011, 07:23:36 PM »
that little white nub? I hired a gorilla to pull it out!
Artful
« Reply #7 on: August 18, 2011, 07:44:45 PM »
Nah Kui, the Speedys have a metal locating pin that the white nubs slip over.
Use one of the two above methods, way easier than what I said.
b.
« Reply #8 on: August 18, 2011, 09:48:48 PM »
 waytogo
2005 M620 | so*cal | terapia.
DucNaked
« Reply #9 on: August 19, 2011, 02:57:44 AM »
I tried this and the pins were in so tight I felt there was a danger of stripping the threads.
So I opted on the side of caution.
csorin
« Reply #10 on: August 19, 2011, 07:48:51 AM »
This has me worried a bit, but seeing that at least a couple people had success, I'll give it a go.
Duc Buz
Bad Cop, No Duc
« Reply #11 on: August 19, 2011, 08:34:32 AM »
Man, much easier method.  I did not think of this, but I do enjoy working harder.  The smarter way is, well, too easy.
Good job DarkStaR. waytogo
11B4P (Ret) US Army
csorin
« Reply #12 on: August 19, 2011, 02:34:15 PM »
M5 screw method took all of two minutes.  Thanks Darkstar. waytogo
DarkStaR
« Reply #13 on: August 19, 2011, 11:02:40 PM »
 waytogo as a plus, the the rolled pins are not mangled up, and could most likely be reused.   Dolph
