January 21, 2025, 12:24:27 AM *
Pages: 1 [2]   Go Down
Author Topic: Swingarm diagram help please  (Read 4079 times)
S2R 800 '07
« Reply #15 on: August 20, 2011, 01:05:47 AM »
From what I have read on a different thread here on the forum, there is a thicker and thinner shim that goes between the footpeg mount and the engine cases.  They could actually be called something different but I am calling them shims because they are super thin and I don't believe are used in the traditional washer sense. I believe either the thicker or thinner one goes against the case and it matters which one. When I removed the swingarm they fell away from the case before I had a chance to note which one went where.  I just want to make sure I put them in correctly.
No, there are no shims between foot peg assembly and swingarm shaft. The foot peg assembly (rubber mount's inner ring) rests on a shoulder on the swingarm shaft's ends. However, there is a thick washer between the rubber mount and the very large outside nut. That washer has nothing to do with axial play of the swingarm.
Punx Clever
« Reply #16 on: August 20, 2011, 05:39:19 PM »
Toodlepip:  You have a PM.
2008 S2R 1000 - Archangel
Pages: 1 [2]   Go Up
