December 29, 2024, 09:20:33 AM
Please Help
Ti Monster Frame*Completed Pics*Headed for DucStock
6
7
8
9
14
Topic: Ti Monster Frame*Completed Pics*Headed for DucStock (Read 76350 times)
Re: Ti Monster Frame
Reply #90 on:
August 27, 2011, 02:46:53 PM »
Want to get silly with steel?
http://reynoldstechnology.biz/our_materials_953.php
Reply #91 on:
August 27, 2011, 02:48:01 PM »
Quote from: stopintime on August 27, 2011, 02:39:20 PM
That's not exotic
Reason I ask is I was offered a custom frame while entertaining the idea of an oversized Monster (matching me)
Monsterize an ST for a larger bike.
Randy@StradaFab
Reply #92 on:
August 27, 2011, 04:06:23 PM »
Some of the bicycle builder told me about some new lighter weight steels they were going to start experimenting with.
I don't think I would want a CF frame. Hell, even Rossi can't ride one of those
jvax
in the land of the rising sun
Reply #93 on:
August 27, 2011, 04:42:08 PM »
how about magnesium for a frame?
'08 R1200GS
'10 M796 ABS Black (Sold)
The Don
Reply #94 on:
August 27, 2011, 09:49:49 PM »
Quote from: RMartin on August 27, 2011, 04:06:23 PM
Yeh but Stoner can
Wise men talk because they have something to say; fools talk because they have to say something. - Plato
Syscrush
Reply #95 on:
August 28, 2011, 06:58:00 AM »
Quote from: Punx Clever on August 27, 2011, 02:16:28 PM
As for the aluminum frames... looking at my swingarm, the aluminum is quite thick. To make a similar trellis style frame out of aluminum that would last, the tube walls would have to be pretty thick too. The question is, would it be cost or weight effective to build an aluminum tube copy of the trellis frame we all know and love?
Yes, the walls would have to be quite thick, and the tubes should probably have significantly larger OD as well so that the stiffness is high enough to prevent flexing which will induce fatigue. We already know what a successful Al trellis frame looks like:
Hellraising-vtec
Reply #96 on:
August 28, 2011, 09:28:17 AM »
its just beautiful...
Reply #97 on:
August 28, 2011, 11:45:59 AM »
Quote from: Punx Clever on August 27, 2011, 02:42:49 PM
chromoly steel has a much higher strength to weight ratio than plain steel, while still being able to machine, weld, and bend easily.
http://en.wikipedia.org/wiki/41xx_steel
Yes, but strength isn't a very significant issue on frames, I.E. we see *very* few frames break or fail in normal service.
A more appropriate spec to look at is Specific Modulus; the stiffness to weight ratio.
A heap of info here:
http://en.wikipedia.org/wiki/Specific_modulus
Examining it for even remotely suitable frame materials, you find....
Steel, magnesium, aluminum, and titanium all have essentially the same specific stiffness, 25x10
6
m
s
−2
So if you want to reduce frame weight, with the same physical layout/design, you sacrifice stiffness.
Reply #98 on:
August 28, 2011, 12:08:19 PM »
Quote from: Speeddog on August 28, 2011, 11:45:59 AM
6
m
s
−2
so what you are saying... a way to reduce weight isn't trough material, but design.
Scooter-Trash
Reply #99 on:
August 28, 2011, 12:12:05 PM »
6
m
s
−2
Only carbon fiber seems to have a better stat in this regard...
Except glass(!) seems comparable to the various metals, so consider me confused.
I'm guessing that the elasticity/ brittleness / fatigue would have to factor in somehow. Otherwise some fool would be building glass frames (Quick! Tell the 'hideous custom' guys about this. It's our chance to thin the herd!
[edit] NM. I read a bit further:
Stiffness versus strength in bending
Note that the ultimate strength of a beam in bending depends on the ultimate strength of its material and its section modulus, not its stiffness and second moment of area. Its deflection, however, and thus its resistance to Euler buckling, will depend on these two latter values.
Last Edit: August 28, 2011, 03:49:35 PM by Drunken Monkey
Punx Clever
Reply #100 on:
August 28, 2011, 07:59:04 PM »
6
m
s
−2
This all makes plenty of sense. But you still run into issues of fatigue loading. 20 years down the road, steel will hold up, Al, Mg, and Ti will have failed.
2008 S2R 1000 - Archangel
The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over. - HST
Billyzoom
I'm having much more fun.
Reply #101 on:
August 28, 2011, 08:02:07 PM »
My Seven mountain bike frame was Ti and I thought THAT was a work of art. And that cost $4,000+ just for the frame....a BICYCLE frame. And this was a few years back. I can't imagine what a titanium motorcycle frame would cost.
She was a beauty! Selling her off paid for my motorcycle gear and a few mods....
Your frame is stunning. Hope it's half as amazing as it looks.
Joel
bikepilot
Reply #102 on:
August 29, 2011, 04:21:45 AM »
Awesome work! imo the Ti will hold up fine -- it makes a perfectly good spring material (rear shock springs on all the factory MX bikes are Ti and they get hammered), it holds up exceedingly well in MTB use and there its really pushed to the limit of just how thin/light it can be without breaking. Yours with the extra thickness will probably last 'till the next ice age -- I'd ride it
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
Reply #103 on:
August 29, 2011, 09:39:48 AM »
Quote from: Punx Clever on August 28, 2011, 07:59:04 PM
You just pulled '20 years' out of thin air.....
I'm ten feet away from a 20 year old Honda, that has 20k miles on it, and it has an aluminum frame.
It's not broken.
As long as the operating stresses are below the limit for the number of stress cycles, failure is unlikely.
I'd be really surprised if the average lifespan of a bike was more than 30k miles.
Most die due to neglect or a crash before that.
Does anyone here have FHE with an aluminum frame cracking in normal service?
Or does anybody here know someone who did?
bikepilot
Reply #104 on:
August 29, 2011, 09:58:11 AM »
I do re aluminum (have physically seen friend's cracked frames), but it was due to faulty casting on one model year, not faulty engineering. My frame, which is of the year that could be so afflicted, has 60k rather hard miles and no cracks. The potential crack point is a rear shock mount. It'll be irrelevant when I fit my fancy bitubo rear shock as its not even utilized by the bitubo. Virtually all japanese bikes of the past two decades have aluminum frames. Very few have cracking issues -- even ones used for stunting.
For that matter my XR650R and CR250R have aluminum frames. Both see impacts and forces way beyond what a street bike will see. Try 120' jumps on a MX track or head-deep whoops at 70mph. Both rock solid and crack-free (and both a decade old now).
2009 XB12XT
1997 TL1000S
2003 KX100 (wife's)
6
7
8
9
14
