January 19, 2025, 09:18:56 PM
Please Help
Ducati 696 won't start
Topic: Ducati 696 won't start (Read 4579 times)
rockcod
August 22, 2011, 09:26:05 PM »
Hi, new owner of a 2009 Ducati 696. Been riding it for a couple of months until I accidentally drained the battery. Tried to trickle charge a couple weeks later with no luck. Purchased a new ballistic 8cell and just put that in last night. Happened to check the fuse on the trickle charger and noticed it burned out. Now I have a new fuse and a new battery.
Tried starting it and it won't turn. Seems to be making a tick tick sound and not cranking. Tried pulling in clutch, turning throttle, pushing the bike and still not cranking. Checked the battery reading and it reads 13.1v. Could it have disabled something when the battery drained for a couple of weeks? Tthis issue is somewhat wiping out my acomplisment/satifaction From removing the gas tank and fuel in swap out battery.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Re: Ducati 696 won't start
August 23, 2011, 04:46:16 AM »
Have you checked the main ground connection is not loose?
The bolt securing your ground is located under the black plastic cover to the left of your front (horizontal) cylinder, if it works loose then all you'll get is clicky-clicky when you hit the starter regardless of the goodness of your battery.
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
rockcod
August 23, 2011, 08:34:45 AM »
So I would have to remove the left plastic cover from the gas tank to see that wire? Or does the whole tank need to come off?
rockcod
August 23, 2011, 05:44:01 PM »
Never mind. I pulled the fuses and checked all the plugs to make sure their tight. Then I hit the button and vroom... It started. Thanks for all the help.
Duc796canada
My first Ducati and road bike!
August 28, 2011, 02:06:41 PM »
On a side note, but close to this, I was getting ready to go out for a ride, thumbed the starter, turn over but no start. I did some checking, checked battery voltage had dropped to 12.3V. I wheeled my baby back in the garage, put her on a charger, 30 minutes later battery had some more juice and thumbed the starter and she purred up with no hiccups! First time I have had any sort of "issue" with this bike, but it seems that the battery has to be in a very specific state of charge, I will be plugging it in the charger when not riding from now on:)
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
