January 19, 2025, 03:18:53 AM *
News: Please Help
Author Topic: S2R1000 Timing Sight Glass  (Read 1320 times)
WetDuc
AKA iamhybris
« on: August 26, 2011, 02:32:02 AM »
I changed my belts with no real problems, but when it comes to setting the vertical cylinder to TDC as outlined in the ducatitechdotcom YouTube videos, I realize my bike has no timing sight glass...I just see a large bolt head where the sight glass would be located.
Any info on why this could be?  Thanks.
« Reply #1 on: August 26, 2011, 02:34:00 AM »
Ducati eliminated the sight glass as it serves no real purpose.
The hash marks on the belt pulleys are all you need to time the belts.
WetDuc
AKA iamhybris
« Reply #2 on: August 26, 2011, 02:38:17 AM »
OK, I had a feeling it was no big deal that the glass wasn't there.
So my question just pertains to tensioning then...I should still position the pulleys at the marks for tensioning the horizontal?  Then to do the vertical tension, should I determine TDC using the spark plug hole, or tension the vertical in the same position as the horizontal.
Sorry for the stupid questions, this is the first belt change for me.
« Reply #3 on: August 26, 2011, 02:41:39 AM »
Don't be sorry.
You cannot use the ducatitech method for tensioning belts on a 1K motor. The pulleys are in different locations and the belts need to be much tighter than the older bikes. There are threads on the board discussing the best methods. Try a search.
Yes, use a screwdriver to determine TDC for tensioning the vertical belt
Ddan
Some of my best friends are whores
« Reply #4 on: August 26, 2011, 02:42:18 AM »
Each cylinder should be at TDC to tension the belt.
                    flogged successfully  NHMS  12 customized.  Twice.   T3 too.
Ducati Monster Forum at
www.ducatimonsterforum.org
WetDuc
AKA iamhybris
« Reply #5 on: August 26, 2011, 02:45:02 AM »
ducpainter, thanks for the ultra quick response.  I really appreciate it.
I'll do the tension at TDC for both cylinders and determine TDC by finger on spark plug hole/screwdriver method.
110Hz is the specified tension for my bike as far as I know, is this right?
Thanks again for the quick help.
« Reply #6 on: August 26, 2011, 02:53:22 AM »
That number sounds right.
WetDuc
AKA iamhybris
« Reply #7 on: August 26, 2011, 02:54:04 AM »
Dude, seriously...THANKS! bow down
