January 18, 2025, 08:57:38 PM *
Author Topic: OEM fork oil weight  (Read 5614 times)
VisceralReaction
« on: August 26, 2011, 08:54:25 AM »
I rebuilt my forks earlier this year and went with a 7 weight.
I really don't like how it handles now and the tire is wearing really bad, really bad cupping.
I wondered if anyone had some insight as to what Ducati uses for OEM weights so I have some kind
of base line to work off of. Also any opinions on oil weight. I've just got stock showa forks on the bike.
Mr Earl
2003 M800 Dark
« Reply #1 on: August 26, 2011, 09:56:55 AM »
I used the information in this page (scroll to viscosity table) to make a blend of two Silkolene products to match the stock "weight" oil.
http://www.pvdwiki.com/index.php?title=Suspension_Fluid
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
bikepilot
« Reply #2 on: August 26, 2011, 10:00:06 AM »
Pretty sure its 5wt for all modern ducatis (and for that matter virtually all modern bikes).  The complicated bit is that different brands of 5wt are actually a bit different in viscosity.  If the oem brand isn't readily available I generally pick a widely available brand and stick with the same thing so I don't have to re-adjust the suspension every time I change oil.
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
VisceralReaction
« Reply #3 on: August 26, 2011, 10:29:29 AM »
That was an interesting read. I used Maxima 7wt and it's alot lighter and faster than what was in there originally.
I may just have to play with this a bit. Since the forks are the cheap OEM showas I can't tune out the fast rebound unless I use a heavier oil. They only have preload adjustment. I may spend the money ($999) and get cartridge replacements
and springs all set up for the bike and my weight from Traxxion Dynamics. But that's out there in the future somewhere.
« Last Edit: August 26, 2011, 10:32:46 AM by VisceralReaction » Logged
VisceralReaction
« Reply #4 on: August 26, 2011, 11:27:33 AM »
Alright after alot of reading I found that for the damper rod style of fork you should be running a viscosty
of about 34 centiStokes at 40C. I'm running a viscosity of 21. I think that if I move to a viscosity of
32 with a 10wt oil I should be back in the ball park of where I was and see if the tire wear improves.
bikepilot
« Reply #5 on: August 26, 2011, 02:04:19 PM »
Even the basic showas and 'zokes on ducatis will be cartridge type, not damper rod type forks unless I'm badly mistaken. It is entirely possible that they spec the thicker oil though -- check the manual for your specific bike on that, no reason to guess on that one.
2009 XB12XT
1997 TL1000S
2003 KX100 (wife's)
VisceralReaction
« Reply #6 on: August 26, 2011, 02:19:13 PM »
You're badly mistaken, wouldn't you assume that since I had rebuilt the fork in the
first place I would know what's inside the fork?
« Reply #7 on: August 26, 2011, 06:30:07 PM »
Dunno, my non adjustable Showas are cartridge, like every other non adjustable Showas I've seen on a Monster.
