October 31, 2024, 03:16:25 PM *
News: Please Help
Author Topic: rearsets  (Read 1246 times)
jason 900sie
« on: August 27, 2011, 02:52:23 PM »
has anyone cut the rear pegs off their rearsets and if so what is the best way of going about it i was thinking a grinder what do you think.I think it will look pretty good.
Düb Lüv
ASE master internet mechanic
« Reply #1 on: August 27, 2011, 07:59:06 PM »
I'm assuming you have a m900ie. When I had oem rearsets, I cut the passenger mount off and rounded off the exhaust mount. Looked nice.
Building, building, building
jason 900sie
« Reply #2 on: August 29, 2011, 05:52:46 PM »
thanks for the input i think it will look prety cool i will post pics when im done!
Bertie
« Reply #3 on: July 24, 2012, 02:25:31 AM »
Do you have a picture ?
Nottsbiker
« Reply #4 on: July 24, 2012, 04:26:09 AM »
I'd use a hacksaw (dunno yank name) as less likely to get clogged with aluminium or jump into your leg.
Used a grinder under my old Hi-Lux (Tacoma) with a wire wheel fitted to get rid of some rust, the mother f____r caught the material of my combat trousers and wrapped itself in nice and tight. Took a while to look down for damage - luckily everything was still 'intact'  Shocked
Ducati Monster 900 (project) Aprilia Tuono 1000
zooom
« Reply #5 on: July 24, 2012, 05:36:02 AM »
angle grinder works very well...
2010 KTM 990 SM-T
freeclimbmtb
From Zero Member to
« Reply #6 on: July 24, 2012, 09:39:00 AM »
+1 for a hacksaw.  Its not THAT much material and its aluminum.  A new hacksaw blade will cut that like butter.  Then use a file and some sandpaper to make it look all purdy. waytogo
2011 Monster 796 ABS
