1100 Evo + PC5? 14t?
Started by pyrocpu, August 31, 2011, 07:20:56 PM
Quote from: pyrocpu on September 03, 2011, 08:59:30 PM
Howie--thanks for the TPS reset procedure. I'll give it a go in the morning. Since the 1100 doesn't have a fast idle lever, I assume I'll just leave that part out. Also good to hear that the speedo is driven off of wheel speed!  Too much time in the car world, with vehicle speed determined at the output shaft of the trans.
DoWork--I did ride a bit more "spiritedly" in the back roads today. Elevation changes, cambered turns--you ARE right--this thing comes alive when moving a bit more. I hadn't really felt the "oneness" with the bike yet--today was the first day with that feeling.  :)
I think what I'll do for now is to ride it until the 1st service. See what dealer can do. I really hope they can re-flash the ECU w/ something more workable. If that doesn't work, I'll have to start thinking long/hard to determine if $1800 on a Termi kit is even logical!
Doh!  1100, no lever.  No problem either.  Just follow the rest of the procedure.
DucNaked
I doubt that your dealer will be able flash your ecu. Only a few companies offer that service.
Dowork had a good suggestion with the pc5 and autotune, however to take full advantage of this you still have to flash your ecu to remove the closed loop (o2 sensors) portion of the map. Without this autotune won't be able to adjust that portion of the map. The pc5 does come with something that tricks the ecu into sending more fuel to that area, but the autotune can't adjust it.
I dont know if the Termi kit would help you. It seems to me that your proplems are in the 0-4500rpm area ( closed loop). As far as I know the DP ECU that comes with that kit retains the closed loop portion of the map.
Mau
My 1100 EVO has 1600 miles on it, I agree with everyone on the fueling issues, however, I've learned to live with them.  The bike does not stall while downshifting, however, it did stall a few times while coasting while grabbing the clutch at low speeds.  The dealer (ProItalia) told me this is a common issue caused by a very restrictive emissions control system, and that there is nothing to do about it.  The bike fires right away when i press the starter.  Since the problem is not very common (5 times in 3 months) and I know how to deal when it happens, for now it is okay.
I would not change the sprockets, I think it works fine above 3K RPM (yes 3K not 4K).
I am nevertheless, disappointed with the lack of power and speed.  I am not saying it is slow, but Ducati claimed 100HP and I was naive and believed them.  The bike is way slower than any 600cc jap sportbike.
The actual dyno readings I think are barely above 80HP (big difference with the claimed 100hp)
I will not sell the bike because of this, I like the design, I like the simplicity of the air cooled twin, I like the riding position, and I like how it handles.  Moreover, going up the Angeles Crest Hwy is a blast.  I am hoping it will keep working for many years to come.
I do have an issue when I upshift from maybe 3rd to 4th or from 4th to 5th.  Sometimes when shifting up, the gear does not engage and it goes somehow into neutral, meaning that if twist the gas the revs just go up and no power is transferred.  I have to upshift again, and then it engages and everything is back to normal.  I am not sure if this is normal (i don't think so) but I am trying to shift quick and hard (the lever) everytime because maybe I am not lifting the lever hard enough?  I will post another thread on this topic shortly.
Narflar
#18
Quote from: Mau on September 04, 2011, 09:58:53 AM
Buying one of these bikes based on power alone is just silly.
I agree 80 is a little bit low but it does feel like it pulls harder than my old M1000.  It definitely pulls harder than my honda.  Also, it's 100hp at the crank, not the rear wheel.  No Dyno is going to tell you crank HP.  Comparing an air cooled big bore twin to a liquid cooled 4 is like apples and oranges.  A 600 4 banger is going to have more horsepower by default just because of the redline.  The EVO redlines at 8500rpm.  But the EVO does have much more usable torque and at least for me is much more fun to ride.
I would recomend changing the front sprocket.  The bike is geared to high.  I can't go below 25mph without slipping the clutch in 1st with the larger sprocket.  Also, with the larger sprocket the higher gears are pretty much useless.
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
pyrocpu
Also agree w/ Mau. I've experienced a "non-gear" between shifts, also in the middle-upper gears. Just a few times. To be fair, my Yamaha also had this every now and then; I think it's my not being firm enough on the gear lever.
Power is good enough for me, even under the break-in-period ceiling of 6K RPM at partial throttle.
DucNaked--I see your point; this is sure starting to get expensive! A dilemma I have though--Termi ECU + PC5? If I went the PC5 route, do I even need the Termi ECU??
Howie--~120mi ride today. No stalls today, after having followed your TPS reset procedure. Not sure if that had something to do with it, or just sheer luck, but no stalls! :)
Now I'm noticing that the front brake pads are dragging a bit, specifically on the right side. Left side rotor, I can still see the cross-hatch machining marks on the rotor; the right rotor's a bit shiny and I can't see the cross-hatching.  Engine off, and backing into my garage, I can hear a slight dragging sound from the front wheel area.
Sorry to all I i sound like a complete downer, or even maybe a borderline troll. I do love my Evo; I just didn't expect so many niggling items is all!
DoWorkSon
Bypass getting the term system. Their slip-ons are no better/worse than the other dozens of manufacturers out there.
Use the money from termi package to get power commander/tune and a set of used slipons
You can modify your airbox to flow better than termi's And doesn't cost anything.
A good tune will benefit you more than a slipon exhaust. It will resolve fueling issues and create a better map which means more power..
2009 M696--SOLD
DucNaked
If you get the pc5 I don't see the point of DP ECU.
Here's what I did. I knew I was going to upgrade my exhaust and filter. I just didn't know what one. I was having some fueling issues I attributed to the closed loop part of the map.
I decided to flash my ECU with a full system, high flow filter, delete the o2 sensors, and raise the rev limit to 9500rpm. I purchased the Rexxer user unit so I could do the flash myself and return the ECU to the stock map if I had to. I ran my M1100s with cored stock cans , dp filter and air box lid. I had this setup for a season until I got my SC Project 2 into 1 full system.
I'm happy with my current set up. And if I want to go to pods and the pc5 with auto tune my ECU is ready to take full advantage of it's features. I don't think I'll do this because my bike runs really good with the current map and I still get almost 50mpg. But you never know  [evil]
thought
cheapest/easiest option would be to buy a set of non termi slip ons from pro italia, get the free reflash, get a k&n filter, and open up your airbox.  i have termi's on my bike and i can say that the fueling got a whole lot better after i put them in.
also, for the shifting issue... that happens to almost every bike, just gotta be more positive in your shifts.  also, everyone here pretty much has a non broken in bike by the mileage listed.  things will start to loosen up properly after 2k+ miles generally.
my 796 started to feel a lot better after 3k miles if that's any kind of frame of reference.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
pyrocpu
Cool. I like the new gameplan: ProItalia re-flash + PC5/auto tune.
Problem is... I think the M1100 Evo is too new--it's not on their application chart! :(
Plus, the pipes I do want, the Boomtubes... also no Evo application! :( :(
EvilSteve
There's no pleasing some people.  :P
2011 M796
pyrocpu
This is true. My wife says I'm hella needy.  ;D
Patience was never my forte!  :'(
EvilSteve
#26
I'm an impatient bastard myself. Although this is my 3rd monster, I have just come of an '09 Daytona 675 and I know some of the differences take some getting used to. Having said that, spending some time on the track helped a bit but honestly trying to make the bike something it's not isn't going to make you happy either.
Here's what I'm doing/have done to mine:
Done:
- Mirrors
- 14t front sproket
- Tail chop
Doing:
- Evotech exhaust hanger (remove passenger pegs)
- Flash spare ECU with increased rev limit (*maybe)
Otherwise, it is what it is to be honest. The exhaust could be a bit louder. I could chop the airbox and core the stock cans too. They'll help a bit but if you want to make this what it isn't you're just going to be unhappy and have a really light wallet. By all means enjoy the thing, tweak it to suit you a bit more but it'll never have the HP of even a 600cc sport bike.
This is my first monster (S2R800) at its highest state of modification:
And this is my S4RS before I sold it:
2011 M796
pyrocpu
Steve--great looking Monsters!
I did install the Evotech exhaust hanger and remove the stock pegs--things do look a lot nicer, that's for sure. I'm not wanting for more HP, just more drivability is all.
First service (the 620mi one) is this Saturday. Will see what the dealer says.
EvilSteve
Yeah, fair enough. I noticed a slight difference post first service but nothing to jump up and down about. ~1200 miles on it now and a couple of hours on the track. 14t helped the most I think but that really doesn't fix the core issue, it's a bandaid.
2011 M796
pyrocpu
Well, kinda bad news.  Good news is that the Evo is still under warranty.
Bad news is this... took it to the dealer for its first service. I mentioned the irregular brake wear and drivability concerns I had, and the dealership staff (both sales & service side) were quite polite, and indicated that this quite common for someone who's just come from a Japanese inline-4 (for the drivability part).  The service manager mentioned they were able to verify my brake concern.  They took the RF caliper off and identified a rather stiff piston.  They were able to retract it, but upon reapplication of the brake lever, that same piston became stiff again, as it slid into operating range.  Dealer mentioned that it may loosen up over time, as thing break-in. Not ideal, but understandable. I agreed that there is plenty of warranty remaining, so OK.
As I was about to hop back on my bike to go home, the dealer technician took it out for a test ride. He came back shaking his head, chatting w/ the service manager. Tech expressed that he has never on a Monster with such horrible fueling; the other 1100 Monsters and even a couple of the other Evos that they've serviced--never like this.
As such, they're keeping the bike for a bit. I overheard the tech talking with the dealer principal that they'll have to hook up the DDA to get a better understanding of the bike's operation, as there were no fault codes when they scanned the ECM, and that they'll need to send the diagnosis to Ducati for assistance.
Hopefully things will get fixed soon. I'm a bit bummed of course, but it is better to get these things worked out prior to the warranty expiring!  [beer]
