1100 Evo + PC5? 14t?
Started by pyrocpu, August 31, 2011, 07:20:56 PM
Narflar
Good luck man, and this is what the warranty is for.
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
pyrocpu
Wow, what a difference!
Got the bike back. Turns out it was a pinched vacuum line. Dealer replaced said offending line under warranty as well as reflashing the ECM and resetting the TPS.
Night and day!
Engine is far smoother. I can run the tach as low as ~2800RPM and is still quite drivable.  Chain snatch is evident below that, but compared to before where I couldn't venture below 4K, it's great. Throttle blips between shifts are quicker & smoother as well--no more stumbling. Apart from the smoother operation of the gearbox (I'm attributing that to the 600mi oil change/service), fuel delivery coming on/off throttle is perfectly seamless. No more throttle snatch (think of a situation say, as you've made a right turn at an intersection and re-applying the throttle). Super smooth.  [thumbsup]
At this point, I really do not think I will be going w/ the Termi slip-ons/filter/ECM kit. Driveability is where I want it to be, and the sound that the OE exhaust makes, in terms of volume, I'm good. I still *may* do a sprocket change to further enhance drivability, and that G2 throttle cam thing, but this bike is plenty quick. Sport Rider magazine just arrived on Thursday: 10.89sec @ 119.9xMPH... That's good enough for me. :)
I think.  ;D
EvilSteve
Glad you got it sorted.
I only put the 14T front sprocket on because 6th was pointless: ~80mph @ 4k RPM.
I agree with you on the stock exhaust.
2011 M796
R0CKETMAN
Yep glad you like it. The G2 will make it even better. As for the termis, they are music to my ears.
