February 11, 2025, 07:19:51 PM *
Author Topic: S4R '04 vs '05 weight difference  (Read 1460 times)
jvax
in the land of the rising sun
« on: September 02, 2011, 07:05:29 AM »
Been reading Ian Falloons's "Ducati Monster Bible" (great book btw  waytogo) and noticed something odd about the '04 and '05 models of the S4R.
The '05 S4R (399lb/181kg) is 26lb/12kg lighter than the '04 S4R (425lb/193).  But the only differences between the two models seem to be in the:
Engine
- Cylinder bore and stroke:  96 x 68.8 for the '04, vs 98 x 66 for the '05 model  (both result in 996cc displacement)
- Although the same 996cc displacement, the '05 year has slightly more power and torque
Brakes
- The rear brake disk is 1mm thicker in the '04 model 245 x 6, vs 245 x 5 for the '05 model
- The front brake pads on the '05 model are Toshiba TT 2172HH, vs Toshiba TT 2802 pads for the '04 model
Other than the engine and brakes changing slightly, everything else (frame, suspension, brakes, wheels) remained unchanged.
So my question, are there other differences that contributed to this weight loss?  Huh?
'08 R1200GS
'10 M796 ABS Black (Sold)
matt922
« Reply #1 on: September 02, 2011, 07:07:47 AM »
metal tank?
jvax
« Reply #2 on: September 02, 2011, 07:22:17 AM »
metal tank?
I thought plastic tanks only started in '06...  Huh?
'08 R1200GS
Kaveh
Dirka Dirka
« Reply #3 on: September 02, 2011, 12:23:34 PM »
I can very well be wrong here, but I remember somewhere around that time Ducati switched from measuring their bikes with all fluids, battery, tires, etc. VS without (like all their competitors have been doing for years prior).  So, they only difference might be how they weighed the bike, if you know what I mean.
muskrat
« Reply #4 on: September 02, 2011, 01:39:14 PM »
nope, mine is an 06 S4R with a metal tank.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
jvax
« Reply #5 on: September 02, 2011, 03:27:30 PM »
So, the weight reduction is not because of a plastic tank.
Thanks for confirming.
'08 R1200GS
riffraff
« Reply #6 on: September 02, 2011, 03:53:17 PM »
Engine
Brakes
The 2004/2005 S4R show the same bore and stroke engine. Not the first time I have seen gross mistakes in Falloon's books...
http://www.ducati.com/bikes/monster/s4r/2004/tech_spec.do
http://www.ducati.com/bikes/monster/s4r/2005/tech_spec.do
jvax
« Reply #7 on: September 02, 2011, 04:15:42 PM »
Fair point.  I've emailed the author to request clarification.
If the engines are indeed identical, all the more reason for me to try to understand why the 05 bike is that much lighter.
'08 R1200GS
jvax
« Reply #8 on: September 02, 2011, 11:52:20 PM »
FYI - got an email response from Falloon, says the data come from the official press releases at the time.
'08 R1200GS
Triple J
« Reply #9 on: September 03, 2011, 07:26:29 AM »
I think Kaveh answered the question above.
« Reply #10 on: September 03, 2011, 07:40:22 AM »
As Kaveh said, it was a change in how they weighed the bikes.
All of the Ducs magically dropped ~10 kg between '04 and '05.
'04 and '05 S4R are both 98x66 bore/stroke.
AFAIK, they're exactly the same bike other than the frame stickers.
I am skeptical of a claimed difference in rear disc thickness.
