February 11, 2025, 07:16:30 PM
Should there be a "Builds/Projects" category added to the forum?
Topic: Should there be a "Builds/Projects" category added to the forum? (Read 2112 times)
2-Skinny
Head Mechanic, Technical and Research Consultant
Measure Twice, Cut Thrice...at least...
September 02, 2011, 12:42:58 PM »
The determining factor for your project bike to count as a build are as follow:
Must have at least 3 of the 5 parts/components from the list below removed from the bike as a whole (and presumably upgraded/modified in some way). Pictures will be required for each build thread as well as a list of intended modifications.
-Wheels
-Forks
-Frame
-Motor
-Swingarm
~135 Yes votes are needed for this to be considered.
Last Edit: September 02, 2011, 12:45:15 PM by 2-Skinny
zooom
Re: Should there be a "Builds/Projects" category added to the forum?
September 02, 2011, 12:45:07 PM »
http://www.ducatimonsterforum.org/index.php?topic=51999.0
DP already moved your origional thread to "Board Suggestions"
2010 KTM 990 SM-T
zarn02
September 02, 2011, 12:57:56 PM »
Quote from: zooom on September 02, 2011, 12:45:07 PM
And from said thread:
Quote from: ducpainter on September 02, 2011, 02:42:47 AM
Start your poll wherever your little sensitive heart desires. When you get 200 responses let me know. The 11 or 12 people that posted in your thread don't justify starting a new board.
September 02, 2011, 01:24:38 PM »
I never said boobies was a yes answer though.
zooom
September 02, 2011, 01:26:49 PM »
Quote from: ducpainter on September 02, 2011, 01:24:38 PM
a Boobies board would be awesomely innapropriate....
2010 KTM 990 SM-T
Scooter-Trash
September 21, 2011, 01:26:08 PM »
Ask and ye shall receive!
Sort of
http://www.ducatimonsterforum.org/index.php?topic=52559.0
After some discussion, we decided a sticky thread to track the build threads was the way to go. If we get enough threads, or maintaining the sticky gets to be a PITA, we might revisit the subforum idea.
(Which is mod-speak for "never!"
2-Skinny
September 21, 2011, 08:07:28 PM »
Sweet! Good call. Thank you.
toodlepip
September 22, 2011, 03:59:48 AM »
Quote from: duck soup on September 02, 2011, 01:24:38 PM
Boobies are ALWAYS a yes!!!! Not any other possible answer!
