February 20, 2025, 07:05:27 PM *
Author Topic: Impedance & Wattage specs for resistors to remedy fast blinking LEDs on 620  (Read 2058 times)
The ModFather
Duck Off
Monster Magnet
« on: September 03, 2011, 09:40:55 AM »
Does anyone have these specs ?
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
OT_Ducati
« Reply #1 on: September 03, 2011, 04:58:16 PM »
Trident EL12 variable load flasher, should work plug and play.
no adding resistors. $12.95 at Advanced Auto Parts
99 M750, 94 900sscr, 75 xs650 street tracker
« Reply #2 on: September 03, 2011, 11:11:27 PM »
Not without major rewiring on a 620, the flasher is integrated into the instrument cluster.  5 watt resisters should work.
OT_Ducati
« Reply #3 on: September 04, 2011, 03:45:00 AM »
oh, did not know.
looks like its resistors for you
The ModFather
Duck Off
Monster Magnet
« Reply #4 on: September 04, 2011, 05:14:28 AM »
5 watts but what about the impedance?
2008 848 Track Bike
« Reply #5 on: September 04, 2011, 09:01:19 AM »
If you get 5 watt resistors for a 12 volt system the impedance will be good.  Your best bet might be to get the resistors from Rizoma.
Ohmic
« Reply #6 on: September 06, 2011, 08:48:36 AM »
The stock turn signal bulbs is 10W. Not sure what your LED pulls. Assume they are ~1W at most.
Thus max (10W-1W) = 9W to have bike flash like stock.
Ohms law... P=VI... V=IR... blah blah blah on a 12V system means it needs to pull .75 amps to simulate stock condition. Thus a 16 ohms resistor will do the thick. Don't go any smaller then that! Depending on the threshold of your flasher-relay might even get away with ~25 ohms. The bigger the resistance the better so you dissipate less heat.
Because this is a 50% duty-cycle single you can use 15W rated device so heat will be at a min.
-Bernard
'It's NOT a Harley... It's a Ducati!'
Bike#1: 2002 Ducati MH900e #1801
Bike#2: 2006 Ducati Monster S2R1000
Bike#3: 2006 Ducati Sport1000
Bike#4: 2008 Ducati HyperMotard 1100
The ModFather
Duck Off
Monster Magnet
« Reply #7 on: September 06, 2011, 09:02:18 AM »
and how would this be wired. In parallel is what I'm hearing. Does that mean one end of the resistor soldered to the positive cable and one end to the ground (black) cable ?
2008 848 Track Bike
Ohmic
« Reply #8 on: September 06, 2011, 09:14:38 AM »
Parallel of course. Remember you want to draw extra current to simulate a stock bulb. So you put your new resistors in parallel to your LEDs. One for each side. Simple as pie.
The ModFather
Duck Off
Monster Magnet
« Reply #9 on: September 06, 2011, 01:33:53 PM »
sorry to be a dumbass but I just want to verify one end of the resistor to positive cable the other end to negative cable?
2008 848 Track Bike
corey
'06 Tang/Black S2R800
« Reply #10 on: September 06, 2011, 04:03:45 PM »
you know, i might have an extra set of resistors that would be plug and play... let me check the garage...
