M800 vs M900 comparison
Started by CookieMonster, September 03, 2011, 09:18:11 PM
CookieMonster
Aside over the obvious engine displacement. 2000+ M800 vs 1999 and under M900, Go!
"Friend don't let friends ride stock"
-S2R1k 992 DESMO LIFE
zarn02
Wet clutch vs. dry clutch
Fuel injection vs. carbs
"ST" style frame vs. "851" style frame.
CookieMonster
Quote from: Speeddog on September 03, 2011, 10:56:00 PM
Can you give me a little more info on this please? Pros and cons? What are the difference in frames (school this soon to be first Ducati Monster owner please). ;)
So far which one is everyone's preference? Carb>FI in performance and sound? More raunchiness?
Ddan
Up to 2002 the Monster frame was based on the 851 frame, '03 to '09 (?) it was based on the ST frame and is supposedly stiffer with larger tube diameter and I thing bigger motor mount bolts.  It also got the rocker rear suspension instead of the hoop.
Some people like carbs because they can work with them, some like EFI because they don't have to.  All Monsters before '00 were carb, the 900 got EFI than and I think the full line got it in '03. The first 4 valve motor (916) went into the S4 in '01 (?)
There are lots of aftermarket options to manipulate the computer, depending on which year/computer you got.  Power in stock trim is similar either way but delivery with EFI is pretty crisp compared to the carbs.
Starting around '02 Ducati started publishing HP and torque numbers at the crank instead of at the wheel so there is an apparent big jump in output in the same motors but it doesn't necessarily mean much.
Ducati Monster Forum at
www.ducatimonsterforum.org
CookieMonster
Quote from: SBK boy on September 04, 2011, 04:26:39 AM
Wow...I'm loving this, I like learning and this is the place to be ;) so right now I'm kinda liking the FI '03+ 900 with ST frame. What am I looking a the tag looking like to be, $5G's?
uglyducky
Quote from: CookieMonster on September 04, 2011, 08:15:18 AM
for around and a bit over $5K you can start to get into the 4 valve s4 monsters especially with winter creeping up.  if you want an air cooled 2 valver (they didn't make the 900 after 02 FYI) - post 2002 options would be the m1000 and then the s2r1000 both really kick ass bikes.  i think a great first ducati would be an '01, '02 m900 i.e.  solid, solid bike.  added benefit of that bike/year is plenty of parts still floating around and a price tag under $4K
2001 996 Biposto - (sold)
CookieMonster
Quote from: uglyducky on September 04, 2011, 09:40:19 AM
And that m900 ie is FI right?
Ddan
zarn02
The '00 and up 900s are injected. As someone said, they only go to '02 or so, when the M1000 took over that slot.
Just a few detail points for clarity:
ST frame entered the Monster lineup with the '01 S4, then across the board in '02.
'00 and '01 M900 were FI, as was '01 S4.
For '02, all Monsters were FI.
sejman
I bought a '01 M900Sie - fuel injected with S package (alum swing arm and bars, some carbon, adj forks, not sure what else is in there). I bought it in '09 to get back into motorcycling after a 20 year hiatus. Not nearly as informed as you are at this point. I've had a blast riding it and modding it. I probably paid a little too much $5500 back in '09 but it was very clean, well maintained and from a dealer (new tires etc).
In my experience parts have been easy to find - including lots of parted out bikes on eBay. I'm not sure if there is a power commander for this engine to modify fuel mapping - haven't seen a clear answer but I haven't gotten serious about that yet.
CookieMonster
Quote from: sejman on September 04, 2011, 11:08:54 AM
Sounds awesome and sounds like I found what to look for. As for the frame it's an ST frame right? The thicker one right?
Ddan
I wouldn't turn down an 851 framed bike for that reason alone.
zarn02
Quote from: CookieMonster on September 04, 2011, 11:23:22 AM
'01 M900 will be the 851-based frame.
I've had an '00 M900, and loved the bike. I'd certainly not turn down a 900 based on the frame.
