"Mystery" noise discovered...not so much a mystery any longer...
Started by BlackKat, September 07, 2011, 06:42:36 PM
BlackKat
As Homer says... DOH! Not at all what I wanted to see.....
BUT.....These showed up today....not that a couple 1080 big bore pistons are gunna solve everything...looks like all new crank bearings and I might have the crank balanced and polished...HELL, I'm in there...WHY NOT!?!?
At 19k miles?
That sux.
Good that you found it before it went nuclear.  :P
BK_856er
Wow.  Guess I missed an earlier thread, if there was one.
What did that sound like, and what causes a piston to fail like that???
BK
BlackKat
Hard to say what exactly the cause was...I have to break her down more so this evening to see what other parts are damaged...Titanium rods anyone? haha
UGH!
duc996
Wow! at such a young age?  i also would like to know what caused it.
       "Monster S4r"
       "KTM SMC 690"
Bishamon
Yikes!  I thought the DS1000 motor was supposed to be 'bullet-proof'!  Scary.
2011 Monster 796
2007 Sport 1000 SE (SOLD) :(
numbskull
Quote from: BK_856er on September 07, 2011, 10:05:28 PM
BK
+1. Owning the same bike, I'd like to hear what the sound/symptoms were that caused this.
BlackKat
No actual symptoms to mention...I ordered a new crank and rods (bearings, gaskets, seals..crush washers...etc) both in stock form. I might send the crank out for polishing and balancing...but for now a stock replacement should be just fine.
I haven't had the bike that long. Maybe put 1200 miles on her or so before all the custom stuff. Looks like perhaps the oil pump failed. Still haven't split the case. The crank and rods were ordered on the suggestion of my tech who has 30ish years working on bikes..most of that with ducati.
Basically, we got the bike back from HMF who made the amazing custom exhaust for our project, threw her up on the dyno for some tuning and upon the 2nd pull, the oil light flashed a bit and the noise began. My tech exhausted every possible "small" test he could before surrendering to the fact it was big...we took the vertical cylinder apart last night to discover what we did...that was where the noise was certainly coming from...
As i have more answers, I'll keep you guys updated. Prolly a freak occurrence. I have to doubt that any of you with the same motor and similar mileage have anything to worry about.
Hellraising-vtec
damn man. good luck. hope its much better when you finish it
any updates?  i was going to say, you're almost better off buying a brand new DS1000 instead of attempting the repair and replacement of all those parts. after labor, i think a engine swap would be cheaper no?
Roaduser
i think he works in the business so prob not paying much if any labour other than outsourced parts.
