Squeak
Started by Justo, September 13, 2011, 08:11:02 PM
Justo
Tricky one for you all.
Ive got a rubbery squeak coming from the front of the bike. Its not the breaks. Its not the shocks, or the forks, and isnt effected when i go over bumps. And only occurs when the clutch is engaged. Be damned if I know what it is. Gonna take off the belt covers on the weekend and have a looksee, but to be honest, not sure what im looking for. Saying that, the belts were replaced about 2K ago...
Any ideas o' wise ones?
09 Black Ducati 696
Bazz21
check your belt tensioners , check and make sure you can turn them easy and they have no movement like sideways wobble , if i was you the first thing too check is the clutch rod bearing on the clucth pressure plate, it makes a squeaking noise and if not fixed will stuff the rod and slave cylinder its a little bearing and if not lubed or replaced often  they dry out quick  cheers bazz
MAX SAYS MORE WOOM WOOMS
Betty
When inspecting your bike you should check the friction coefficient between your footwear and the walking surface ... under certain circumstances a squeak may be audible.
Justo
Quote from: Betty on September 13, 2011, 09:45:16 PM
Shit. what if Im bare foot and knee deep in water?
09 Black Ducati 696
Justo
Quote from: Bazz21 on September 13, 2011, 09:36:14 PM
Cheers Bazz. Certainly a starting point for my investigations.
09 Black Ducati 696
ducmeister
I find that my open clutch squeaks a bit on take up sometimes.  I just thought it was normal.
'02 M900ie, DP CF mufflers, DP mirrors, CF side covers, beer tray, belt covers, and sprocket cover, K&N filter, clear indicators, Speedymoto 5 spoke clutch cover, etc, etc, ad nauseum.
brimo
Motor running, or not?
From a story by RAT900
Betty
Quote from: Justo on September 13, 2011, 09:54:43 PM
The squeak will only get worse.
Justo
Quote from: brimo on September 14, 2011, 02:46:43 AM
Running. But only when in gear (and obviously moving). I can hear it right up to about 30kms/hr, but after that the engine/pipes gets louder, thrown in with wind etc, so not sure if its still there in 3rd gear and up or I just cant hear it.
09 Black Ducati 696
dragonworld.
A regular squeak that gets faster as you speed up?? ???
Or a constant squeak that chirps constantly and is noisier over bumps??  ???
Justo
Regular Chirp. Doesn't get louder. Doesn't get faster either. Bumps have no impact on it. But as soon as I pull the clutch in it disappears completely.
Good mystery aint it! Thing is, its gonna bug me (and ill bug you guys) for another week or so as wont have time to open her up until next weekend, and even then i probably wont know what im doing. Ha! worst comes to worst and I cant figure it out its off meadowbank we go.
09 Black Ducati 696
dragonworld.
I'd be going Bazz's route and pull the clutch cover off and the pressure plate and replace that little bearing (Cheap $6-$7 at bearing servives) and also pin
the other side the clutch slave cyl, and make sure it hasnt been spinnning in the piston and have a look at the little orings that can get chewed up damaged!
Bazz21
good one dragon id forgot about the little o rings that one place that never gets serviced with a little grease it should be checked and lubed when you do a service  [thumbsup] cheers bazz
Justo
I'll be damned. Not a single squeak on the way in to work this morning. (20km ride with traffic & 100kmhr+ - so a good range)
Ahh bikes!
09 Black Ducati 696
vossy
Just as I thought, you probably evicted the family of mice living in your air filter box.
Wulla! no squeaking noise.
"Life's short" "Ride More"
