bar end mirrors help!!
Started by Cortez11, September 15, 2011, 02:36:56 PM
Cortez11
Hey i just bought some new bar end mirrors from sportsbike shoppers on ebay and can't seem to get them to fit correctly/ tighten enough to actually stay on.  Has anyone else used bar ends from them, or another company that might have some suggestions. Thanks a lot.[img]bar end/img]
take risks
2000 VFR 800 - wrecked
2007 Ducati Monster 695
elyse
looks like he tried to post a pic but failed..
here's the link to the board faq's on how to post a pic :)
http://www.ducatimonsterforum.org/index.php?topic=109.0
says elyse :)
The ModFather
Typically these are installed with a a bolt and a rubber barrel that goes in the bar with a nut on the other side of rubber barrel inside the bar. When the bolt is tightend it squeezes the barrel which expands against the insides of the bar. To install these prior to inserting the bolt/barrel/nut tighten the bolt to create the squeeze on the rubber barrel just a little bit before putting it in the hole. Also add a little spit before sliding it in.   [drool] This helps in most situations similar to this as well.   :o Once its in tighten the bolt and you should be able to get it firmed up so it doesnt spin in the hole. If that doesnt work try less or more  [drink] and  :-*
When removing it make sure you dont loosen the bolt all the way otherwise the nut can fall into your handlebars which can be a pain to fish out. Not that this has ever happened to me I can just predict these things sometimes.  ;)
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Narflar
Quote from: Cortez11 on September 15, 2011, 02:36:56 PM
are they the right size for your bar?  Mine had an extra sleeve that goes over the insert for larger bar sizes.  It ended up I had to use the extra sleeve.
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
Cortez11
Yeah, i've tried all of it.  It has an extra outer sleeve, and I even attempted to tighten them without even installing but they still wouldn't get big enough...maybe they did send me the wrong size.  Thanks for the help.
Cortez11
thanks for the pic uploading info
ChrisH
Flip the collar around so that the slits face the mirror. Slide the collar towards the end (opposite the mirror) and tighten the screw so the slits start to flare out. Then installl in the var and tighten all the way. That's how mine are installed anyway and they are rock solid.
2010 Monster 696
2005 Honda Ruckus
1985 Honda Spree
-Austin Texas-
bdfinally
+1
When I bought those a few years ago, they sent them to me bassackwards too
Cortez11
Thanks man that helped majorly.
