fuses keep's on blowing
Started by ducatigirl100, September 15, 2011, 05:07:28 PM
ducatigirl100
hi  ;D
I've got a new topic otherwise, another problem !!...lol   [roll]
1995 m900,  47 ooo miles
I keep blowing fuses !!    It's the 7.5A fuse for the turn signals and it keeps on blowing ... I do 10  miles and no turn signals a no rear light at the rear!!   when i change the fuse everyting seems to be OK, but 10 miles after that it's blown up again !  [bang]
Doe's someone has an idea from where the problem could come from....???
ducatigirl100
P.s.   all the fuses hare in the rigth place.   ;D
ducatigirl100
greenmonster
Have you switched to LED indicators or changed rear light?
A bad ground somewhere here causes shorting/fuse problems.
M900 -97
MTS 1100s  -07
ducatigirl100
I,ve check al the wiring today it seem's ok ( I'll check it again to make sure) could it be a connector that is unplug??
Quote from: ducatigirl100 on September 15, 2011, 05:19:58 PM
Not likely...
look for a chafed wire
greenmonster
Connector unplugged, esp a ground one, will cause problems.
M900 -97
MTS 1100s  -07
ducatigirl100
No lead indicators ...I've just put the original back on whit a homemade bracket to hold the turn signals  ...i'll cheak for bad ground on saturday....
ducatigirl100
So, I'll  check for ;
chafed wire
connector unplug
bad ground's
other idea's ? just to make sure i have a lot on my plate ...  lol  [Dolph]
P.s.  Tanks for the pointers
greenmonster
#12
Rare problem, but fuse holder can be semigood as well, fuse eroded/bad contact fuse-holder..
Do start w 10 fresh 7.5A fuses....... ;)
you`ll need them.
And +1 on chafed wires.
M900 -97
MTS 1100s  -07
zooom
Quote from: greenmonster on September 15, 2011, 05:35:59 PM
you`ll need them.
and make sure that the connectors on the tailight aren't tweaked just enough that they aren't touching each other, or an exposed end of the wire there....
but yeah...
2010 KTM 990 SM-T
ducatigirl100
Problem solved!!  ;D
tanks for the pointers guy's  [bow_down]
It was a connector that was unplugged ( from  the front break )  and also a wire for the rear left signal light was almost cut from chafing.    plug it all together and everyting seams to be fine ...    [Dolph] [thumbsup]
