February 07, 2025, 11:32:29 AM
How to core stock low mount pipes?
Topic: How to core stock low mount pipes? (Read 1958 times)
Timmy Tucker
Banninated
September 17, 2011, 09:10:58 AM »
I have the stock low mounts on my '99 M750. They have been chopped to about 2/3 their original length, but not completely cored. They're not particularly loud... the bike is approx twice as loud and nasty w/ the pipes removed. I'd like to find a happy medium between what I have now and the sound of an open exhaust.
I guess I need to completely gut them out and experiment with packing and a perf pipe, but I can't seem to figure out a way to remove the sleeve w/o cutting off the inlet tube. I glanced over the tutorials and came up empty handed for a complete gutting of the exact pipes that I have. Any suggestions?
1999 M750 - "Piggy"
2007 S4RS
Re: How to core stock low mount pipes?
September 17, 2011, 10:15:44 AM »
One of these in 3/4"-1". Pull off the pipes, then go in from the outlet.
Need more noise? Make more holes.
Latinbalar
September 20, 2011, 07:02:06 AM »
There are a few ways of doing it but it starts getting surgical after a bit.
with a gas torch you can cut away the walls and pipes going into the pipe till you hit the front of the pipe. This way you can stay with the original stuffing.
or you can remove the aluminum sleeve and on the body of the exhaust you will see where the inner walls have been welded to it. Grind those back and everything inside pulls out (not easy).
Scooter Montgomery
Milford, NH
September 20, 2011, 08:58:09 AM »
If they are like my 03 low mounts coring them isn't really hard, more time consuming than anything. You will have to make some custom plates and have the inner stainless steel tube welded to it. A grinder with a cutting blade will be your bestfriend.
2003 620 Half Dark/ Half Silver 35,000 happy miles
Scooter Montgomery
Milford, NH
September 23, 2011, 07:12:56 AM »
Any luck?
muskrat
September 23, 2011, 05:54:32 PM »
drink lots of beer and plenty of xanax. I did it once, never again.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Timmy Tucker
Banninated
September 24, 2011, 09:15:02 AM »
Haven't attempted anything yet. Might be a few weeks before I do anything, been stupid busy at work.
1999 M750 - "Piggy"
2007 S4RS
Latinbalar
September 28, 2011, 08:49:05 AM »
ohh and while your at it hacking away and all shorten the cans to about 3 inches from the hanger. Makes the bike look super sexy.
Scooter Montgomery
Milford, NH
September 29, 2011, 08:45:44 AM »
I shortened mine 5" from stock. Its slightly shorter, 1/2" or so, than my tail chop.
hooligan machinist
"Slightly" modified 97M750
October 08, 2011, 05:48:42 PM »
I cut mine down by 50%. Looks great and sounds mean as hell without additional coring.
cell # (931)-316-2020
