14T Sprocket for Monster 1100 EVO
Started by godudi, September 19, 2011, 11:23:08 PM
godudi
Hi,
I want to change the front sprocket of my M1100 Evo to 14T.
I was searching the web and DP 2011 accessories catalogue and couldn't find the M1100 EVO listed on any of them.
Perhaps the catalogue was published before the M1100 EVO was launched so maybe it could be the same sprocket as the M796/1100/1100S although it is not in the list.
Can anyone advise,
David
rubbersidedown
Im taking my Evo in this week to have the 14t installed. I called my dealer and they said they had one in stock so I think they may be the same. As far as the catalogue, nothing is listed for the evo in the 11 catalogue, but you can go to ducatiusa.com and find accessories that way.
2011 Monster 1100 Evo
godudi
that's the only one I found and it says not suitable for ABS models:
code 96824701B
Front sprocket 7mm (525) - T14
Front sprocket 7mm (525).
Notes: These accessories are not suitable for ABS equipped models.
pyrocpu
Geez. I was hoping to do a 14t on my ABS bike. That sucks!
Wonder what makes it not compatible.
thought
it's compatible with abs, it's an error that ducati never fixed up in their literature.
google about duc's, abs, and the 14t.  you'll see a lot of threads out there about it, but in the end someone heard from ducati saying that they work just fine.
i cant say anything about TC and the 14t though, but i'm pretty sure that should work out find too.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
take risks
2000 VFR 800 - wrecked
2007 Ducati Monster 695
Curmudgeon
The ABS is calibrated for the stock gearing and the ABS has been EC Type Approved with that gearing, hence the disclaimers. 14T works fine with ABS (and TC on the evo). Terminal lockup might differ less than 1 MPH. Hardly anything to get your knickers in a twist over it. Checked all this out myself prior to fitting a 14T to my 796. Your dealer probably knows this too.
Quote from: pyrocpu on September 20, 2011, 07:31:19 PM
godudi
Quote from: Curmudgeon on September 20, 2011, 08:38:12 PM
"Thank you for contacting Ducati North America.
The ABS system uses both speed and RPM in its computations, two things directly affected by changes made to the gearing ratio. The ECU that governs the ABS system is programmed to work with the stock gearing on the bike only.
We hope this provides you with the information you were after.
Regards,
Customer Service
10443 Bandley Drive
Cupertino, CA 95014
Phone: 408.253.0499
www.ducatiusa.com"
But like you said, perhaps they just cover their ass..
thought
http://www.ducatimonster.org/forums/tech/199089-latest-dna-14t-abs.html
"Dear Tom,
Thanks again for contacting Ducati North America.
After reviewing the Ducati ABS operating principles, and conferring with colleagues, it has been determined that the independent operation of the ABS will tolerate a -1 tooth countershaft sprocket change or a +1 rear sprocket change.
If you have any further questions, please feel free to contact us or an Authorized Ducati Dealership. To find an Authorized Ducati Dealership, please visit www.ducatiusa.com and click on "DEALERS" or utilize our dealer locator by phoning 1-800-231-6696.
Regards,
Customer Service
DUCATI North America
10443 Bandley Drive
Cupertino, CA 95014
www.ducatiusa.com
Tel: (408) 253-0499 x4411
Fax: (408)253-4099"
abs is fine.  like i said, google some more if you want to see the results of a whole lot more people asking the same exact question.
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
godudi
Quote from: thought on September 21, 2011, 06:26:28 AM
"Dear Tom,
Regards,
Customer Service
10443 Bandley Drive
Cupertino, CA 95014
www.ducatiusa.com
Fax: (408)253-4099"
Thank you for the clarification.
godudi
I am taking my bike to my local dealer on sunday morning to install the 14T cs sprocket..will keep you posted..
pyrocpu
Let us know godudl! You'll be the guinea pig! :D
giantdefy
I contacted 4 different Ducati Service techs at 4 different dealerships asking if I could switch from the stock 15/39 to a 14/41.  All said the exact same thing, sprocket change will not affect ABS/TC on the monster.  The monster gets its speed reading from the Tone rings on the wheels, gearing change has no affect on ABS/TC and speedometer.
The monsters are geared way way too high.  even with my current 14/39 setup, the M796 can only cruise at 77 mph in 5th gear, any slower and I have to shift to 4th or the bike starts to shudder.  6th gear is only good at 95mph and above, I can shift to 6th at 85mph, but the bike shakes and no power to accelerate.
Narflar
I had the dealer put a 14 tooth on my Evo before I even picked it up.  I've had no issues with the brakes.
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
Curmudgeon
Quote from: giantdefy on September 24, 2011, 04:33:36 PM
Agreed about the noise and emissions reg gearing on the 796, but bad shuddering under 4,000 - 4,500 RPM under throttle sounds wrong. They do that when new because they are very tight. How many miles do you have on it now?
BTW, I also had the 14T fitted from new but wouldn't want to go any shorter. I'd guess the mileage would be horrible. Getting ~ 45 MPG right now at 750 miles on the clock.
Incidentally, mine takes throttle from 3,500 now without a lot of complaint. When new it was almost as bad as a Hawg.  ;)
